Maytag EPIC MFW9700S Front Load Washer Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't start my washer machine, it is in the controlled lock and will not let me do anything else.
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Apr 16, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
901110
Points
3465
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Control lock light is on and will not do any other functions..will not start or anything.
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
2helpful
The control locked light is on and the washer won't start or do anything.
Try pressing the "End of Cycle Signal" button for 4 seconds. This should release the control lock. If it does not then you have an issue with one of the controls and service may need to be run. Let me know if you have questions.
Thanks!
Washer locked. door lock light blinking. start button light on. won't do anything.
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Control locked
hold the padlock button for 3 sec, if that doesnt work replace the user interface
2answers
1helpful
Control locked light
check your panel closly the lower right hand button is marked"control lock" hold for 3 secs and youll release the control lock
9helpful
Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
1helpful
Control Locked
you have to push a button on right side which tells you to hold down this button for control lock
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
