Question about Hitachi 43FWX20B 43" Rear Projection Television
Have sound but no picture
My Hitachi Tv have sound but no picture. Repair shop suggest flyback, so I bought a flyback and replace it, still the same problem, what should I do next?
  • 927 Answers
Good Day, cassper;
At this point call an Authorized Service Center, or check LED's light or more important the LED's that don't light.
Good Luck, big IRISH.
Posted on Aug 16, 2008
SOURCE:
TV is making a crackling sound on left side of tv from the back and shut off after several times hitachi 51f59a v61050869
Sounds like the flyback transformer. You can get a replacement flyback from www.tvrepairworld.com and assistance to help you identify if the flyback is the issue
Jun 05, 2011 | Hitachi 57F710 TV
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
The red in pictures is off. It slants.
i have hitachi 53" tv and model number 53sbx59b.
tv flyback gone so i need a flyback and i want to know the price for that
Oct 19, 2009 | Toshiba 43A61 43" Rear Projection...
No picture or sound
could be blown flyback transformer
Aug 22, 2009 | Televison & Video
Hitachi 65 in rear projection tv
can you identify the flashing item because it sounds like the flyback or the high voltage splitter can you send me a picture of the part thats flashing white please?
May 09, 2008 | Hitachi 65F59 65" HDTV
1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
can you see the g2 from crt sound like you list your g2 from
the flyback.i need m# plz
Mar 30, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Rca 36" f36650
Usually the horizontal output does become shorted when the flyback goes. I would replace the H output as it only cost around 3 dollars. You can check it with an ohms meter out of circuit to determine if it is indeed shorted or open.
Mar 19, 2008 | RCA F36650 36" TV
Green is going, going, gone?
I would suggest check the the secondary side of the power supply for around 130VDC if that voltage is found to be lower than 120VDC I would suggest to replace CP80 with a 100 [email protected] vdc. Part # 218374
Check Globalsemi.com for these parts.
Jan 13, 2008 | RCA F36650 36" TV
Hitachi 32 No Picture or sound
if you are hearing a click and electrical statics when you try to turn it ON, the flyback of the tv is busted there are alot of reasons for that problem lighting is one so dont leave the cable screwed in if ever youre going out for a long time. you can have it replaced by a technician ( flyback). but it would cost you. and im not sure if you can find an orginal flyback considering its 10years old. there are replacement flybacks but quality would not be as good as the original one.
Oct 06, 2007 | Hitachi 32UX51B 32" TV
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
