Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
My bunn is too slow
Help, i love my bunn coffee maker but lately its takes forever to brew a pot of coffee, i have taken the basker of and unscrewed the little thingy the hot water comes out of and cleaned it. but it still takes 20 mins or more to brew 10 cups. please help cause i can not afford a new coffee maker. if i have to buy anew one it will have to be a cheap mr. coffee or something. once you have used a bunn, no coffee taste as good.
  • 1 more comment
  • bamagirl304 Sep 17, 2007
    as much as i payed for my coffee maker and you want to charge mw to trouble shoot it. that sucks!! guess i will be buying a mr. coffee.
  • Anonymous Mar 21, 2014
    my coffee maker has gradually become slow at brewing and coffee is not hot enough
  • Anonymous Mar 27, 2014
    my coffee maker wont get hot
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
I have had this happen when I used non bunn filters . perhaps they non bunn are too small thereby letting the water run over the top My bunn takes 3 minutes when it's clean to brew 12 cups .
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
if the coffee is ground too fine, it'll take longer to brew through. either grind more coarse or call bunn for a flow restrictor (800) 352-BUNN (2866)
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Water coming thru coffee maker very slow
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Dec 29, 2012 | Bunn NHB Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Incredibly slow dripping coffee
get out the spring that came with it and ramrod the tube
un screw the shower head and clean that first the ram out the tube then reolace the head
this pot is not heat sensative when brewing coffee, like most of the other types
also pour in a quart of white vinegar, followed by 4 or 5 pots of water
Dec 13, 2008 | Bunn NHB Coffee Maker
Bunn Cooffee Maker is not making full pots of coffee
I would ask if this machine has been moved lately- for cleaning or has anyone put anything new around the brewer? If someone has moved this brewer, they might have caused a kink in the line coming to the back of the brewer. this will restrict the water flow to the brewer. this will cause the brewer to brew only part pots of coffee.
Nov 13, 2008 | Bunn NHB Coffee Maker
Slow brewing
I have had that problem with my bunn and I unscrewed the nozzle and it didnt help.My pot came with a wire so long u are totake that wire and stick it up in there and it cleans it out .If that does not work run cleaner threw it but i would not use vinegar.Thats the best i can do,it worked for me.
Jan 11, 2008 | Bunn GR10 Coffee Maker
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
1,784 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
Inky Fingers
Inky Fingers
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
