Question about Xerox WorkCentre XE80 Laser Printer
E2 paper jam error on Xerox workcentre XE80
I get an E2 error but the paper feeds past the laser cartridge and then tries to go through the space above the drum and that is where it stops. I can use paper 5 in wide or envelopes and all is well. I think there may be a small piece of paper stuck under the left side output but I cannot see anything. I need help in how to get it out or get into this section to check it out. It appears to get stuck between the output roller and the secondary cartridge. When I remove the paper from the back it has a uniform soft fold across the leading end of the paper about 1 in wide for the full width. Richard
  • 2072 Answers
SOURCE: XEROX WORKCENTRE XE80 DISPLAYS AN
Try this procedure.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Posted on Jul 18, 2008
  • 8 Answers
SOURCE: paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Posted on Aug 26, 2008
SOURCE: learn how to use my scanner on my xerox workcentre xe80
dont know how to scanner
Posted on Dec 08, 2008
yooperbud
  • 8637 Answers
SOURCE: Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 239 Answers
SOURCE: Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Posted on Oct 16, 2009
Do not know what E2 alarm light means
Error Code for Canon MP160 E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error VOTE ME IF THIS SOLUTION IS OK
Aug 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Have a jam error. paper folds in front of print roll
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Mar 31, 2011 | Xerox WorkCentre XD125F All-In-One Laser...
Recently replaced drum cartridge on our Sharp AL-1217 photocopier and copies are now coming out smeared with toner. I have done what I can to clean the parts.
First of all, remove both toner cartridge and drum unit. Wipe the space they occupied with a clean cloth till you see its clean. Wipe also the upper part where the laser unit is, that is the place you will see a small glass-like strip above where the drum fits, till clean. Check that the paper tray is not dirty with toner and if it is , wipe it clean. Slowly turn the semi-circular feed rollers while wiping with damp clean cloth till clean. Then check that you replaced a new drum and blade and that the main charger above the drum is clean. Also check that the drum seal blade , that small nylon paper-like seal is not broken , and if broken reinforce with a clear cello-tape. Then, re-insert your cartridges back into the machine and a very clear copy will come out. Please try and you won't fail.
Nov 23, 2010 | Sharp AL-1217 Copier
What does E2 mean??
Error code
E3-3 = Paper jam
E4 = No ink
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
visit manufacture website for more user manual guide..
Jul 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have an error E2. I have tried to reset the
E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
I had a paper jam and got the paper out but still shows E2
E24 = Purge unit error (bagian cleaning head)
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma Mp150 keeps having E2 flash
Clear the EEPROM:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Our copy machine keeps flashing E2. There is no paper inside the machine.
Remove the toner and drum cartridges. Using a flashlight, look inside the front of the printer. At the rear of the cavity there are two large rubber rollers. On the floor, about an inch to the right of the rightmost roller, there's a tiny black plastic feeler that's supposed to protrude from a slot in the floor and be pushed down by paper as it feeds through. Occasionally it sticks in the down position, causing the printer to think there's a paper jam. Running a finger over it usually unsticks it so it will pop up where it belongs. I usually flick it down a few more times to make sure it's free to pop pack up. I guess the spring tension, light by design, is sometimes not enought to overcome friction.
Jul 05, 2008 | Xerox WorkCentre XE88 Laser Printer
Xerox WorkCentre XE80 Laser Printer Logo
411 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
