Question about HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 - paper jam but no paper
Tried turning printer off/on, unplugging powerline, resetting ink tanks... this hasn't worked.
  • 45 Answers
Try unplugging, waiting 20 seconds then plug back iin. This resets printer, check for paper stuck in the back on the rollers and the top rollers...make sure printer isn't dirty..if rollers are dirty whip off with damp cloth..make sure your using the right type of paper....if these steps don't work and your under warranty call the warranty company....this is a hardware problem that needs to be looked at
Posted on Apr 16, 2009
Hp deskjet 3845 printer will not print and it is no paper jammed, it is installed properly
it sounds like your printer is not connected to the pc or laptop,check the USB cable properly.another problem is paper jam or which leads to qeueing of docs to be printed.
Mar 01, 2013 | HP Deskjet 3845 InkJet Printer
My Deskjet 3845 printer 'on' button keeps blinking and doesn't print anything.
Usually an indication of a paper jam. Check it thoroughly for any scraps of paper and see what happens.
Feb 28, 2011 | HP Deskjet 3845 InkJet Printer
The green light on my HP Deskjet 3845 is flashing ..when I try to print it tells me there is a paper jam ..there is no paper jam. I have inspected the printer carefully, reloaded the paper. It will not...
i think u should check for peices of paper ,tiny objects etc that might be obstructing the movement of the paper. also check that the print head is not disconnected from the belt you can check this by slidind the print head from side to side and ensure that both of them are moving hope this helps.
Oct 19, 2010 | HP Deskjet 3845 InkJet Printer
Says paper jam but there isn't one. Have done all the troubleshooting steps..I do mean all of them. how do I get the paper jam status off my little hp deskjet 3845
I ran into a similar problem on another HP Laserjet Printer so this is what I found out from some tough researching. There is a step that requires a specialized tool which is inserted into the printer to clear the problem. This may be caused by an internal (no diagrams available) optical sensor that somehow gets covered with paper dust or blowback (ink particles blown backwards into the printer)? This tool may clear the problem, which I've heard is similar to a strip of heavy card stock. I have not found the procedure for this just that someone mentioned the same problem. Last resort is taking in the stupid printer to be serviced. Hopefully an HP tech will come forward and describe the procedure and maybe some maintenance diagrams. Good Luck.
Jan 26, 2010 | HP Deskjet 3845 InkJet Printer
Paper jammed and was pulled free now after correcting printer does not respond
Try powering it off for 5 minutes including unplugging the power cord and then turn it on and see if that helps. Also restart the pc.
Nov 09, 2009 | HP Deskjet 3845 InkJet Printer
Paper jam cleared but printer does not work
Jalavoie, I don't know if this will be a solution for you but some things to try: I would assume by now you've tried restarting your computer and in turn the printer as well, but have you disconnected the printer from the power. Pull the power lead from the back of the printer wait 30 seconds and replace it. Hopefully this will reset the ink carriage and fix the problem.
Failing that, have you had a GOOD look inside incase there's a bit of paper torn off still there - not necessarily from the one you just removed, it could be from a previous jam.
As you had moved the ink carriage by hand, are you sure you did not bump any of the ink tanks - for surety remove each tank and reseat it. Note:: the ink carriage should never be manually moved.
If none of this helped, can you describe what position the ink carriage is in a and what sounds the printer is making (if any) and exactly which lights are on or flashing.
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 31, 2009 | HP Deskjet 3845 InkJet Printer
Blinking green light
Clear the paper jam, or replace the ink cartridge. Possible causes are the paper jam or ink cartridge. The other solution is to disconnect the power from your printer and reconnect it. Hope this helps!
Oct 22, 2008 | HP Deskjet 3845 InkJet Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
479 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
