Question about Batesias V172RTNRA 17 in. LCD Television
My screen powers up, turns on and displays for one second.
My screen powers up and turns on. even shows an accurate display. then one second later it goes black. I can turn it off and back on and get the same thing. any suggestions
    President:
  • Batesias Master
  • 1,779 Answers
It's most likely a few capacitors in the power supply. Not a major repair. Locate a reputable svc co. to take it to.
Posted on Apr 16, 2009
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
Display problems with 2 yr old Tecra
Hello
about the first problem, most likely overheating.
May 13, 2008 | Toshiba Tecra A4 Notebook
Tip
Playstation 3 no display?
Have you changed from A/V to HDMI and now cannot get a display?<br /> <br /> Playstation 3 not showing video but playing sounds?<br /> <br /> Follow these very simple steps to bring your Playstation 3 back to life!<br /> <br /> <u>Step 1.</u><br /> <br /> Turn the Playstation 3 off into standby mode (red light on)<br /> <br /> <u>Step 2.</u><br /> <br /> Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep<br /> <br /> <u>Step 3.</u><br /> <br /> Wait for the Playstation 3 display to initialize.<br /> <br /> Your Playstation 3 should now display properly and you can get back to your gaming!<br /> <br /> Hope this tip helps you out.
on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
Posiflex jiva tp5800 screen turned red on the bottom and now its black
This is related to the backlight of the lcd screen. It could be the light itself or the inverter. The parts are available: http://www.posiflexusa.com/SP_LCDRepairKit.php
Nov 24, 2013 | Posiflex Jiva 5800 All-In-One...
LG 55LD520 picture problem
the problem with these sets (all brands) is it could be any board in the set or even the panel used for the display---
Jun 06, 2012 | LG 55LD520 55 in. HD Ready LCD TV
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
Toshiba Satellite M30 display problem
I decided to read this and I am not exactly 100 sure what the proplem is. I did want to offer a suggestion though. If you are having problems with both the screen and an external monitor, the problem may be with the graphics hardware. If you have a card, it may need to be replaced. If not, i'm very sorry. The motherboard may need to be replaced. Hope this helps.
Nov 10, 2008 | Toshiba Satellite M30 Notebook
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Batesias V172RTNRA 17 in. LCD Television Questions
Batesias V172RTNRA 17 in. LCD Television Logo
60 people viewed this question
Top Batesias Televison & Video Experts
Are you a Batesias Televison and Video Expert? Answer questions, earn points and help others
