Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need to change the code on a 03 opener, someone in the community keeps opening my garage door with theirs.
  • 504 Answers
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
(THIS CAN BE HIDDEN IN THE WALL)
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 30, 2010
DOOR OPENS ON ITS OWN
Someone else in the neighborhood has the same code programmed into their door controller. If you have the instructions for your door opener, change the codes in the opener and your remote clicker.
May 28, 2016 | Building Materials
Our Stanley 7200 professional garage door opener opens on its own. How to fix?
change the channel or code. It is set to a code that a neighbor is using. Yours is opening when they request theirs to do so. Next time, run outside and see who is just driving into their garage.
Sep 05, 2015 | Building Materials
Device opens and closes on its own. Nothing is blocking the door's sensors
someone else has the code or the same code for their own door and are screwing with you,change your code or change the sensor
May 11, 2015 | Building Materials
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
The garage door opens on it's own. The receiver and the remote are both new, replaced by a professioanl. we have re-programmed the remote code 5 times. All electrical lines have been checked and are...
There is a possibility that your are receiving interference from another wireless device that operates on the same wireless system as your garage remote. For example, someone else could have the same system for their garage, especially if you live in a community.
Jun 02, 2011 | liftmaster Garage Door 1/2 Hp
Well, to make a short story long, a policeman knocked on my door and asked me if I knew both my garage doors were opened. The temperatures were subzero and single digits above 0. I alone and no one but...
Sounds like someone else in your neighborhood has the same garage door opener and it's on the same radio frequency as yours. And yours may be opening theirs. Your frequency can be changed, but you'll have consult your Owners Manual on how to do it or contact Sears.
If someone in your family carries the remote garage opener in the pocket or purse, it can be accidentally triggered. I say this, because my mother-in-law used to do it all the time.
Feb 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Someone is able to open our garage door, they keep doing it, how can we change the security codes or what do we do to keep this from happening?
I assume "someone" is opening your door using a handheld remote, right? If that is the case, CLEAR all remotes from the main console (there should be a sticker with directions on how to do it on the main console). Re-add all the remotes onto the console - this should take care of it. If you have a keypad outside - change the pin on that too.
Sep 15, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My neighbors remote opens and closes my garage door opener Series
Chec your receiver unit located somewhere by the door usually you could change the code your self.
may need service by the expert.
Jun 29, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain CLT1D Remote Problems
Its very possible for someone esle to have your code I would say try two things. The first thing is too check your wall button wire shake it is a little make sure there are not cuts or staples in the wire its self cause it to short out and run. Then change your codes is pretty easy on the back of the opener unit its self there are the dip switchs you will most likly need a step stool. Just move 2 or so of the dip switchs and then move the same ones on your remote. On your remote the dip switchs should be undernether the batter cover
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
95 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
