Question about Seagate U Series X 20 GB Hard Drive
Hard drive doesnt work
I have a dell precision workstation 210 MT BIOS revision A08 and it came with a 10 gig western digital (WD 100)hard drive and i am trying to add a slave drive that is a seagate (U series 5) 20 gig i got out of my windows 98 so it is a little older I set the jumpers to the right spots but when i turned on the computer it said that there was a hard drive thermal probe failure and it also said (memory write read failure at 30000000,read 0206f000,expecting 00ef00ef decreasing available memory) do you know what this means because it is really confusing i know it worked before i put the slave drive in and also how do i formatt the slave drive and what do i do at the setup screen because it is way to confusing for me thank you for your time - Justin
    Problem Solver:
  • 9 Answers
I think you have to connect the slave HDD on a separated cables (data & Power) and also check your power supply abilities for handling all you devices (HDD's and others)
Posted on Mar 23, 2017
Dell precision 530 bios ssd
This is a little bit long shot, but check also if there is an updated firmware for the SSD (you will need access to another machine in order to upgrade it). I will look up if I find either a bios for the Dell that is working or another solution
Mar 23, 2014 | Computers & Internet
I cant get my Dell Precision 690 to recognise a hard drive
Double check the bois to ensure you have all the Sata ports turned on. I have found in some Dell computers the only ports turned on are the ones in use when shipped from the factory.
Feb 01, 2012 | Dell Precision Workstation 690 - 750W...
What is the slave patern for 500 gig hard drive
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 10, 2010 | Western Digital WD Scorpio Blue WD5000BEVT...
Replacing a hard drive on Sony PCV-RX550 with a Western Digital 320 gig. With the orig disc as primary master, the wd drive is recognized by the bios as secondary master. But when I remove the original...
if you want to connect two hard drive together then remove the jumper of the primary hard drive and don't touch the setting of the secondary drive then start the system.always make primary drive which have the os.
Jan 26, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Mar 04, 2009 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
Dell Precision 490 constant reboot after ghost image completed
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
External hard drive disk space
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
Aug 17, 2008 | Western Digital My Book Essential Edition...
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Seagate U Series X 20 GB Hard Drive Logo
51 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
