Question about Dymo LabelWriter 310 Printer
How do I load the tape into this old dymo label maker? (Hobbyist 1895)
I have an old Dymo Jet 1855 Mk11 and the tape will not advance when embossing or cutting
I was having the same problem. When you load the tape make sure to push it through the slot just in line with the white lever that sticks out of the left side of the machine.
Jan 12, 2014 | Dymo LetraTAG Thermal Label Printer
Enlarge font dymo handheld labeler
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see dymo.com for numbers).
^CM
Nov 18, 2013 | Dymo Labelmanager Lm 160 Handheld
Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Apr 24, 2010 | Dymo Hobbyist Labelmaker Printer
How do I reset my Dymo lablel maker I have ! ! ! ! ! ! when in use
!!!!!! is a (rather unhelpful) error code that means basically that it can't print for some unknown reason. If the tape is not jammed in the printhead, and the tape seems to move freely, then generally it means the machine is broken.
To be sure you can call Dymo tech support on 020 7341 55 29 (UK)
If it's under warranty, you can return by going here:
http://global.dymo.com/enGB/ServiceAfterSales/default.html (UK)
If not you'll need another one...
http://www.dymo-label-printers.co.uk/Dymo-Label-Maker.html (UK)
You don't say which model you have, but if it's the one in the picture it should still be under warranty as they're fairly new and come with a 3 year warranty (in the UK at least).
For US or other countries go to www.dymo.com and select your country, and then the returns and contact information can be found there.
Nov 04, 2009 | Esselte Dymo LabelManager 120P Compact...
How do I change the tape in my dymo QX50 label maker?
Where the cartridge has a hole in it, make sure the tape is IN the print head, not over or under it. Also, check the type & color of the tape. They have some strange combinations that are only visible under certain conditions.
May 22, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Apr 06, 2009 | Dymo LetraTAG Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo LabelWriter 310 Printer Logo
2,950 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
