Question about Windsor SR12 Sensor Bagged Upright Vacuum
When I turned on the sweeper it would not start. I put a different power cord on it and it worked fine. now it won't start but the light on the brush and the bag full will flash when i turn it on and off but it wont start. i have 2 of these doing the same thing. do you have any idea what could be wrong. I have checked for clogs but have found none. Bob
  • 58 Answers
Its sounds to me like the computer board inside the machine has gone bad. Keep in mind that the filters in these machine do need to be replaced regularly to keep the vacuum working correctly. Any good vacuum shop should be able to fix your problem. Reguardless of what they might tell you there these really are one of the best machines on the market and definatly worth having repaired.
Posted on May 29, 2009
  • 72 Answers
There is a filter somewhere that should pull out for you to clean and replace
Posted on Apr 16, 2009
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush on my bissell prolite multicyclonic vacuum won't turn. It seems like it is jammed, but I checked for anything that might be stuck in it and don't see anything. Is there a reset button?
I had the same problem with my old Bissell sweeper ( I bought a new rotating brush each time this happened then I bought a new sweeper the next time it happened -last Dec. 2009.) Unfortumately I bought a new Bissell and now it is happening again to the new sweeper. I do clean the brush often but what has happened is that the hair somehow gets inside the brush via the end caps???This sweeper does have end caps that can be removed for cleaning --although not that easily when they are locked up. I did this yesterday but before I could remove the end cap I had to use a pin, scissors, etc. anything that I could get into the groove to remove lint, etc. that caused it to lock up. Then when I got the end cap to move a little, I pried it off. I found hair, etc. inside where the metal rod is which I don't think should be happening --I used a seam ripper also to try to get some out. I have owned many different brands of sweepers and have never seen this problem before. Then, I put the end cap back on, however, it was not smooth on the inside--almost like it had melted when it locked up. So, the sweeper brush now moves but it is noisy. I guess I will buy another brush -- but this seems ridiculous for a new sweeper--the customer service rep told me that the brush does wear out.... but not on a sweeper that is less than a year old. There is no wear and tear on the brushes. Oh, and the CSR told me that they haven't had people call about this problem --I am guessing they are just buying new brushes or new sweepers. The sweeper def. has great suction but I think other brands do also..
Nov 11, 2010 | Bissell 17G5 PROlite MultiCyclonic Bagless...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Shark Euro-Pro cordless vacuum won't start
Sounds like it needs to be serviced. Call customer service here to help you.
Tel: 1 866 98SHARK (1 866 987-4275)
Is it still under the 1 year warranty.
Good Luck and Please Rate FixYa!
Mar 12, 2009 | Vacuums
Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Jan 15, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
V1917n shark vacuum won't run
Mine did the same thing, actually both of them did. I had ordered two at the same time. I love these vacuums. They are so convenient to use and do a terrific job, at least until they acted up and did not want to run.
The first one would power up for a second or two and then quit and the three lights would flash. I tried everything to get it to work. I switched batteries and the charger cord with the new one, but still it did the same thing. So, I opened my second new one up and began using it. I worked for several months and then just here a couple of days ago it too began acting just like the first one did.
I took the corner brush off and then the rotator brush off and removed all the hair, strings, and etc., from around the brushes and also all the areas of the vacuum where any could be at. I put it all back together and it turned for several seconds and then the three lightw would flash again.
I had given up on them working again and was going to be boxing then both up and send back for replacements and was looking at buying another brand of cordless rechargeable sweeper. I had found one to buy, but still I knew that I would miss the Shark vacuums.
Well, tonight I took the second one apart again and looked at areas where I might have missed any hair or strings that might have wound around anything that might keep the brush from turning. I found some wound around the rotator brush end piece that is on the side opposite to the belt. At first I thought that a rubber gasket was worn that fit over the little metal rod that is at the end of the rotator brush, but when it still would not run, then I was thinking that the belt needed to be changed.
I have read somewhere, where someone said that it was hard to change the belts. Well, with the Shark that I have, which has three speeds and the handle that drops down in the middle so that you can vacuum under beds and etc, it is easy to change. There is a tab that you have to push that is next to the wheel on the belt side of the underside of the vacuum, and it opens to reveal the belt.
Well, when I opened it----------there was a tremendous lot of fibers and hair wrapped around the belt wheel and in the chamber leading up to the wheel that the belt attaches to the rotator brush. After taking the belt off the bottom wheel and cleaning all the hair and fibers off it and removing all the rest in the chamber, I put everything back together and it powered up and ran just like it did when I first got it.
I also got the first one working also. I don't have to send them back and have to wait a long time for replacements. Just a word of advice------------keep the rotator brush clean and the area around the belt at the bottom and anywhere else where hair and strings can wrap around. Keep a check on it weekly and it might keep them running.
Jan 14, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
No power to head of Kenmore Progressive canister vac
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Mar 05, 2008 | Kenmore 22812 Bagged Canister Vacuum
Windsor SR12 Sensor Bagged Upright Vacuum Logo
147 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
