Question about Belkin (F5U237) 7-Port USB Hub
HP printer will not print over wireless network using Belkin hub
HP printer psc2410 will not print over wireless network using Belkin 5 port USB hub. It used to work and then something changed and it won't print anymore. The Belkin software recongnizes it's there, but it says not connected. And we can not get it to connect anymore. Not sure what changed to make it stop working. Since it quit working, we have upgraded our McAffee software and followed their steps to allow it to work but this didn't solve our problem. The printer does work if you connect the USB cable directly to the printer.
  • 83 Answers
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Posted on Apr 24, 2009
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
No connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Disappearing files from Hard Drives
find if you portable deviceshas any SAFETY REMOVE function, if you using hot plyg and unplyg function without firs safety remove it causes this action, same is in flash drives. because writting process is not finished when unplug and last transaction had not been writen and file allocation table has wrong data in it.
Aug 18, 2009 | Belkin Wireless USB Hub
Can I wirelessly network my HP Officejet J5780 printer?
What you are saying will not work . The J5780 only connects with a USB. It does not have a J45 connection. So to play with the "built in network server" would do nothing. You would have to have some way to convert the USB to a J45 so he could hook it to his Wireless Router. His only alternative is to hook it to another computer that is used as a Wireless Slave that is shared or to get a print server. Hower, Belkin does make a wireless USB Hub that converts 5 USB's to J45 and can be hooked to you Wireless Router. It also has a built in Print Server. You can take this device and instead of hooking it J45 to the Router you can hook it to a linksys Bridge and now the USB HUB from Belkin becomes completely wireless. And has a Print server to boot! The model number are Belkin "Network USB Hub" and the Linksys WET54G.
Since the Hub connects to the USB devices and then converts them to a J45, to link to a network you can hook it to the llinksys device and convert it to a wireless network usb hub. It also has a print server built in.
It works. I own the same printer all in one and if you search on the internet you can pick up both devices on the cheap.
Jan 05, 2009 | HP Officejet J5780 All-In-One InkJet...
Blue screen with multifunctional printers
Normally the USB hub is design to connect to the device that doesn't consume electricity like handy drive,MP3 player.So in your case the multifunctional printer, I think this one really need a direct connection to your PC,instead of going through USB hub.Try to move some other device to connect to this hub and connect your printer directly to PC..due to many restriction with printer like electricity,port,etc...
Apr 17, 2008 | Belkin Wireless USB Hub
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Open Questions:
See all Belkin (F5U237) 7-Port USB Hub Questions
Belkin (F5U237) 7-Port USB Hub Logo
407 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
