Question about Maytag Washing Machines
TUB LEAKING FROM CENTER ABOVE THE TRANSMISSION
  • Anonymous Apr 23, 2009
    My machine leaks above the transmission at the base of the tub. The parts are cheap I would love to be able to fix this myself.
    Champion:
  • 219 Answers
Tub bearing and seal needs replaced its a big expensive job
Posted on Apr 17, 2009
2 Suggested Answers
The_lRipper
  • 116 Answers
SOURCE: WATER LEAKING FROM ABOVE THE WHAT APPEARS TO BE
Your center seal where the shaft goes through the tub to the transmission is bad and is letting water leak bye it. I would not repair the machine it will run you $350 to $600 to fix you have to buy a bearing kit which has the seal in it and the labor involved is a lot normally 4-5 hours to complete the job I would not attempt this on my own unless you know what your doing. I would start looking for a good quality used one or a new one sorry for the trouble hope this helps.
Posted on Jan 07, 2011
Washer is leaking water? perform pavt910aww
Check near the center of the underside of the outer tub where the transmission spins.
Mar 11, 2015 | Washing Machines
Washer leaking
fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Sep 25, 2012 | Washing Machines
WATER LEAKING FROM ABOVE THE WHAT APPEARS TO BE THE TRANSMISSION IN THE CENTER OF THE MACHINE
Jan 07, 2011 | Maytag SAV2655A Top Load Washer
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from bottom of tub during filling, around center shaft.
your outter tub seal is leaking between the drum and transmission might want to have a repairman tackle that job
Jan 17, 2010 | Maytag PAV2300 Top Load Washer
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Leak underneath tub
check for a broken seal at center of tub , if so , write down the brand & model and go to an APPLIANCE PARTS SHOP, and get a new RUBBER SEAL KIT, hope this helps , AJ
May 20, 2009 | Washing Machines
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Jul 15, 2008 | Washing Machines
Washing Machines Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
