Linksys WPSM54G Print Server
Problem for Linksys WPSM54G Print Server
Can't connect to WPSM54G after configuring it
By sng133 on Apr 16, 2009
I followed the instructions on the CD for the WPSM54G print server and configured it as directed. After I disconnected the Ethernet, turned off and on the print server, the CD proceeded to find the wireless print server but it could not. The same error is displayed - connection failed.
The main router is broadcasting its SSID and the MAC filtering is not on. I can only ping the static IP for the WPSM54G when it is connected to the main router via the Ethernet cable. Once it is trying to act wirelessly, I can't even ping the static IP.
Solution #1
posted on Jul 26, 2009
Somewhat Helpful)
sukhiii
Rank: Master
Rating: 82%, 6 votes
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Was this helpful?
Yes
No
Popular Solutions for Linksys WPSM54G Print Server
Questions and Unsolved Problems for Linksys WPSM54G Print Server
Do you recommend Linksys WPSM54G Print Server?
Answer
Answer
print server seems to shut down and loose conectivity after a while.
Answer
my laptop will not recognize cx5500 printer driver first it tells me, it can be done, but then the... (More)
Answer
I've successfully installed this Print Server to use with an HP5510 Multifunction Printer but no... (More)
Answer
Installation Linksys WPSM54G is OK. Printer HP Color Laserjer CP2025 is recognised but at installing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys WPSM54G Print Server:
Top Print Server Experts
Rank: Guru Guru
Solutions: 1424
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Print Server Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
