Question about Seagate U Series X 20 GB Hard Drive
Hard drive doesn't work
I had an old emachines windows 98 computer with a seagate U series 5 20 gb hard drive in it i got a newer computer it is a dell workstation 210 mt but it only had a 10 gb hard drive in it so i took the hard drive out of the emachine and tried to install into the newer one and it doesnt work whenever my computer boots up it just stops everything and goes into a never ending cycle of rebooting but when i took the old hard drive out the computer works again so i dont know what to do please help!!!
Thank you for your time - Justin
    Scholar:
    New Friend:
  • 69 Answers
Are you still running W98? It's possible it needs to be refigured via the jumpers in the back, next to the power connector. I'd suggest googling the drive, find out how to configure it for your new machine.
Are you booting to the new machines existing HD (5 Gb)? If so make sure your boot order is 5 Gb, then #2 the new drive. You don't really have to even put the new drive in the boot order. You will need to set the jumpers however. Probably not SATA. If one is IDE and the other SATA can't use them on the same motherboard.
Good luck
Posted on May 08, 2017
  • Seagate Master
  • 17,000 Answers
You cannot just throw a hard drive from one computer into another there are specific programs that perform specific jobs for individual components that are different in all computers.
askanything
  • 151 Answers
SOURCE: Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Posted on Sep 25, 2007
Benimur
  • 6966 Answers
SOURCE: SEAGATE HARD DISK DRIVE PROBLEM...
I am venturing a guess, but it could possibly be your memory and not your hard drive.
Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 01, 2008
SOURCE: how to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
Posted on Jul 11, 2008
pincer
  • 377 Answers
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Posted on Oct 04, 2008
graysand
  • 558 Answers
SOURCE: Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Posted on Oct 04, 2009
Testimonial: "Very helpful! Thank you!"
Seagate 9SF2A4-500 external hard drive on Windows 98
Windows 98 will not run a drive that large, so that is your problem. You will need to connect it to a newer system, and break it down into small drives by setting up different partitions. Perhaps it will see it then. Also, most manufacturers are no longer supporting Windows 98. You really need to just upgrade your system to a newer OS.
Feb 13, 2010 | Computers & Internet
Seagate barracuda 7200.9 (ST3160811AS) SATAII is visible in "BIOS" with the correct information.... ...but no visible in "MY COMPUTER" or "DISK MANAGEMENT" please give me some help...i could find...
Hi Live,
This sort of thing is generally indicative of one of two things. One a failing drive or two a drive controller that isn't supported(or updated) in windows.
If you can reply back with your motherboard make, model and Rev # I will be happy to check if there are any relevant update you may need.
If the updates are not the issure, try using the drive on a newer computer, if it shows up, the motherboard is old and unable to support it properly, if it does the same thing on a newer model chances are it's dying or in it's death throws.
Let me know the above info and how you make out on the newer machine,
Chris
Aug 05, 2009 | Seagate Barracuda (ST3160811AS) (20 Pack)...
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard drive doesnt work
i think you have to connect the slave HDD on a separated cables (data & Power) and also check your power supply abilities for handling all you devices (HDD's and others)
Mar 23, 2017 | Seagate U Series X 20 GB Hard Drive
I don't have an instruction manual for my Seagate 160 GB External
Well, if it is a USB Drive, you can locate the drive on your Computer. and using Windows explorer would be a lot easier, click on start, all programs, accessories, Then click Windows explorer, and on the left hand panel, you can then search your drives and located the data that you want to copy and paste. For example, I am going to copy my documents from my (C:) drive, and I then will paste onto my USB flash Disk Drive (J:)..you will see the files go from (C:) to (J:) drive once you start the process...thats it!
Apr 01, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Formating hard disk
IF the old PC motherboard will recognize the drive while booting up, Windows 98 will also see the drive after boot-up. You may have to reformat the drive into smaller partitions.
All you have to do is physically install the drive in your old computer and attempt to boot. After the computer boots up, if the drive does not show up shut down and put the drive back in your old computer. Use the manufacturer's partitioning software available on their website to change the drive from one 250 Gb partitions to five 50 Gb partitions.
Feb 15, 2009 | LaCie (300728U) 250 GB Hard Drive
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
External hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Jan 01, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r windows........win-xp-sp2
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
Seagate U Series X 20 GB Hard Drive Logo
57 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
