Question about Apple iPod shuffle MP3 Player
Cant get shuffle to work when not conected to pc
My shuffle seems to work well when it is sync but after disconecting it it wont turn on I have opened it and cheked the battery and it has 3.6 volt charge.I have restored it and load music again but the same.
  • Anonymous Feb 15, 2008
    it won
    t restore
  • Anonymous Jan 02, 2009
    cannot locate the eject icon after charging my shuffle
  • 150 Answers
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Posted on Sep 15, 2007
SOURCE:
My ipod wont shuffle anymore
How to Fix an iPod Shuffle That Won't Turn On
Things You'll Need:
* iPod Shuffle iPod USB cable Power adapter
The iPod Shuffle is the smallest member of Apple's line of MP3 players. During the device's lifetime, you may find that the iPod freezes or seems to not turn on anymore. Since the iPod Shuffle does not have a display attached to it, you cannot be notified of any device errors. However, there are several troubleshooting steps you can take to repair your iPod.
Instructions
Plug the iPod USB cable into the iPod Shuffle and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod Shuffle to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod Shuffle memory.
Connect the iPod Shuffle to your Mac or PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Hope it helped.
Have a nice day.
Feb 22, 2011 | Apple iPod touch
My ipod shuffle wont sync up or add songs says its loading yet nothing ever goes to the ipod
try sync-ing it to anothe pc or usb port, it happens sometime after prolong sync's
Jun 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Hi there. i have the 1st ipod shuffle and im struggling to sync some new songs on it. I have made up a libary of songs i want but cant seem to remove the previous songs on the ipod for the new songs. can...
for syncing of songs in apple ipod u need to have itunes downloaded from google. then u import those songs into itunes and then syn it in ipod with previous songs removed
Feb 20, 2010 | Apple iPod shuffle 1st Generation (1 GB)...
Syncing without deleting content on ipod shuffle.
this happened to me too with my iTouch. i had to plug it into my comp, quickly stop it from syncing, then i went under the tab on the left for my iPod. when i set it to manual syncing, it fixed the problem, but then you'll have to do everything by hand. if you want to keep it automatic, i think you'll have to let it format.
Feb 27, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Unable to sync ipod shuffle.
Thats because you cant sync Music into a shuffle Lol
Hope i helped
__SmartChick10_
Feb 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod download
you need to have 'Itunes' on your computer
Download it here: www.apple.com/ipod/start
through this program you'll be able to convert audio CDs to your ipod & buy new songs from ' the itunes store. '
Dec 17, 2007 | Apple iPod shuffle Second Gen. Silver (1...
My 1week old ipod shuffle 2nd gen wont turn on
i got mine downloded music listend to if for about 2 weeks mabye and it was all fine..The i went to use it the next day it it wouldent turn on at all i tried to reset it adn all but nothing works....im useing windows vista so no problem there but on the ipod theres not lights and it seems to get hot while charing for a small amount of time..lets say maye 30 mins its pretty warm...is this a li po battery problem or what?
Aug 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod shuffle MP3 Player Logo
411 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
