I HAVE A PANASONIC AG-1980 VCR. WHEN I PLUG IT IN AND TURN IT ON NOTHING HAPPENS.
  • 88 Answers
First, check your power source. Unplug a light or other working electric (120v) item and plug the AG-1980 directly into that exact plug. Once your power source is confirmed (120 V AC, 50-60hz, appx 33 watts) your VCR should come on. If you know you have power and it is not working, it will need service by a professional. DO NOT ATTEMPT to open and work on the VCR yourself. The entire manual for this AG-1980 VCR can be downloaded for free at the following site....
http://www.retrevo.com/d/ds/progress?doc=314064acc523a6e1712d667d7d9b7688&u=1
Posted on Apr 19, 2009
  • 15,935 Answers
Power supply problems are a good possibility in this case. If you have a DC voltmeter, you could check the outputs. In standby mode, you should see at least a +5 volt supply. This standby line is necessary to power the logic circuitry, particularly the microprocessor.
If you dont have much electrical repair experience - professional help should be saught. There are potentially deadly voltages stored in capacitors that must be discharged properly to avoid injury.
If you have such experience - i will continue....
In the full on mode (VCR power on), other voltages should be present in addition to the +5. You should see a +12-14 volt, (powers the capstan, video drum, & other motors if present, & possibly a supply for the LCD display of somewhere around -35 volts.
A common cause for a non-working power supply in early VCRS ('80s & early '90s), such as Panasonic manufactured rigs, is defective electrolytic capacitors used to filter the above noted supplies, especially the in the +5 & +12 volt lines. Sometimes a capacitor in the primary side of the supply will go bad, causing the dead symptom.
Obviously, a schematic is beneficial especially if you are a novice.... however the age of the VCR makes it highly unlikely to be found.
If by chance bad electrolytics are the cause, and you wish to repair it, I'd suggest using capacitors designed for these switching power supplies, such as the Panasonic FC series.
If by chance you do have one of these early rigs, these were excellent units. Most early VCRs were made like tanks, very unlike the "made to break" junkers of the last 10+ years.
I generally do not spend time locating faulty Electrolytics!! Change all Electrolytic Capacitors at one shot. It is cheap (about $4USD for all of them) and it will eliminate checking all of them, and prevent future failure.
Thanks for using FixYa!!
Posted on Apr 16, 2009
Panasonic AG 1980, displays d u 10, ejects tapes
It hates what you have put into it. OBB SEEN
Apr 23, 2014 | Panasonic AG-1980 S-VHS VCR
Colour Noise and Dim Display
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Feb 19, 2008 | Panasonic AG-1980 S-VHS VCR
Tip
Panasonic AG-1980 display
If the display fades out, the problem is solved virtually every time by replacing a few electrolyctics on the display board, specifically C1,24,26,28 and 29.
on Dec 24, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic ag 1970 manual 1980 vhs
that is ages old...forget it.
Jun 26, 2013 | Panasonic AG-1970 VCR
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
The main light on the front panel went out on my 1980 desk editior. how much to repair?
The display on the AG-1980 goes dim mostly from old age - replacement of the display usually cures the problem, though you may need to replace some or all capacitors in the power supply.
Jan 22, 2009 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 Wont load cassette
probably caused by the mechanism being mis-timed. re-timing isn't difficult, but a service manual is absolutely necessary.
Nov 16, 2008 | Panasonic AG-1980 S-VHS VCR
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980
most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Sep 24, 2007 | Panasonic AG-1980 S-VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
