I guess you meant the Security Key for the wireless. You need to manually set the encryption type and key in order to connect.
When connected to the Wireless router with a cable, open up command prompt (Start->Run...->cmd [OK]), type ipconfig and note the IP address of the Gateway.
Copy paste this Gateway IP Address into IE and [Go]. you'll be prompted to logon. Try defaults if you don't know (Admin, Admin or Admin, password).
Then depends on the model of the Wireless router you need to locate settings for the wireless connection. Recommands WPA-PSK 2, AES.
