Question about Kitchen Appliances - Others
Berkel 909/1 manual slicer turns off after short period
light goes when plugged in
hi and low speed work
the problem is the motor will turn off after 5-15 seconds on either speed and then when the start button is pressed will run again for a odd number of seconds and then just turn off
could this be a relay problem ?
or is it something else
SOURCE: Berkel Slicer won't start
Had the same problem, test your capacitor, that should be the cause of it. Good luck.
Posted on Nov 21, 2008
  • 20 Answers
SOURCE: Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Posted on Jun 13, 2009
rickead1
  • 1998 Answers
SOURCE: BERKEL 825 THIS IS NOT
Did you hook up the wires to the right spot if you have them backwards it wont work message me back with the diagram that you have as well as the part if your positive you wired the switch correctly also sometimes when you order parts you can get a part in that is defective as well even though it is new you can also take the swith back out of the unit and perform a continuity test on the switch itself to check to make sure that it is not defective if you are unable to do these electrical tests with a multi meter i suggest you call a technician any further questions message me back Thanks Again
Rick
Posted on Jan 05, 2011
SOURCE: Can we use common mineral oil to lubercate a
Mineral oil is safe to use. You NEVER NEVER want to use any type of vegetable oil or pan spray. It will do more damage than good to your slicer. The good food machine oils are a just a high quality mineral oil.
Posted on Mar 22, 2011
  • 195 Answers
SOURCE: need a parts manual for Berkel slicer 825E
Have you looked at Berkels web page
Posted on Dec 09, 2011
Berkel slicer wiring diagrams
If its an an ac unit (i.e plugged into the 110Vac wall outlet) and the switch is the on/off switch, it doesn't matter which one goes on which terminal.
Aug 01, 2014 | Berkel 829E Gravity Feed Slicer Manual...
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Need a parts manual for Berkel 825E slicer
Hi I have four (4) different one's I will try to attached them here for you
it won't let me attache dbut here is th eaddress good luck , if you need parts get back to me i have serveal parts for each type of slicer
http://www.retrevo.com/d/ds/progress?doc=1096457ae4ac5b3050fb47ab5d5835a6&u=1&rk=0.12324874425124166
Oct 25, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
I need a manual for a berkel slicer
here you go
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/BK46700.pdf
Oct 10, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Manual on meat slicer
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 26, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Sharpen berkel slicer blade
collee; take the blades to a machine shop or a small engine shop they will be able to sharpen them.
Dec 21, 2009 | Sewing Machines
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Oct 17, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
315 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
