Question about Dell Axim X5 Pocket PC
Backup battery on Dell Axim X5 varies on charge left, even after complete charge. One minute it's 100%, then 0%, then 100% again within a few minutes
  • Anonymous Nov 04, 2007
    have the backup battery warning of needing to be charged problem. Reolaced battery 6 times with no solution.
  • 3,186 Answers
Install Active Sync latest version off of the Microsoft site. Turn off automatic SYNC ..... change it to manual sync.
Then check the connections on the watch battery----- you may need to add a piece of tape to the battery lid to get a tight connection. Carefully bend out the tab that contacts the battery. Wipe the battery off with a clean rag before installing.
Posted on Nov 04, 2007
SOURCE:
Dell Axim X5 Backup battery
CR2032 battery. Backup your information first.
Jan 03, 2010 | Dell Axim X5 Pocket PC
Backup battery discharging
hi thanks for using fixya!
You have to bring your Dell Axim X5 PPC to a service center, to check further the back up battery if needs to change it.
If you need further assistance, let me know.
May 28, 2009 | Dell Axim X5 Pocket PC
Dell Axim PDA backup battery
There is a small wafer type battery inside the case. Similar to a CMOS battery in a PC. You need to replace it. You can do it yourself if you have the right tools, i.e. tork drivers. Battery is around $4.00 .
Dec 12, 2008 | Dell Axim X5 Pocket PC
Dell X5 backup battery
I will attempt to answer both questions and give some insite.
1st- No, the charger does not recharge the backup battery. The battery is the same kind of battery as you would have in a watch which at this time are not rechargable, but that would be a great idea.
The way it works is that when the main battery is charged the X5 uses that as its energy source. Only when the unit is off and or the main battery is depleated does the back-up battery kick in. Hence the name (back-up battery).
As for a solution to your problem. It sounds to me like you have a problem with your primary battery. I don't believe that it has much time left or it may just be a corrosion problem. I would try clening the battery contact point on the battery as well as on the X5 with some alcohol and a q-tip. I would also check the contacts where the back-up battery is. I have worked on watches before and their batteries will sometime cause some corroding.
Sep 15, 2007 | Dell Axim X5 Pocket PC
Backup battery problem
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Sep 04, 2007 | Dell Axim X30 Pocket PC
Backup Battery draining fast
what version of windows moblie are you using? Is it overclocked?
Aug 04, 2007 | Dell Axim X5 Pocket PC
PDA will not turn on
If it isn't completely broken, I would recommend a few things:
1.hold down the power button, and push reset. It will ask you if you want to wipe the contents of your device. Push the button to cancel.
2.Pull the main battery and the backup battery. This will wipe everything on your device but it may get it up and running again.
Apr 03, 2007 | Dell Axim X5 Pocket PC
Dell axim x5 back-up battery
It is a knows issue for the backup battery not to take charge once they reache 0%. The backup battery is a pretty crappy NiCD cell. As the job it is supposed to do is pretty important I recomand to have it changed. For most PDA's this is a standard 3V battery. You should have your pda dissasembled and either have the battery manually charged (to see if the PDA can handle it later) or simply have it changed. This shouldn't be an expensive repair. For more info, feel free to reply. Good luck.
Feb 16, 2007 | Dell Axim X5 Pocket PC
Restoring Backup to New Axim
The backup utility included on your Dell Handheld will backup your data to a storage card. You can restore on your replacement handheld from that storage card. From your Host PC, you can go to Tools | Backup/Restore and do a backup to the Host PC, and you can then restore after syncing the replacement handheld for the first time.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
124 people viewed this question
Ekse
Clive
Clive
