Question about Brother GX-6750 Typewriter
Carrier stays to the left
When I turn the typewriter on, the carrier just moves to the extreme left and stays there (slight grinding noise). Then it starts beeping. And all I can do when it beeps is to turn it off. What can I do to fix this problem? Please help.
  • 23 Answers
Look inside the machine and make sure nothing has fallen into it that may be blocking the carriage from reaching it's "home" position. Sometimes a lift off spool will fall off and do that.
Posted on Apr 21, 2009
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Carrier slides to the left and stays there, buzzing. After a minute or so, it beeps. Then stops altogether.
Check for debris in the carrier area that interfear with the movement, turn it off and move it by hand. Try a little WD40 on the silver shaft it slides on.
DickyO
Jan 20, 2010 | Swintec 7040 Typewriter
Brand new typewriter. Set up according to
When turned on the carrier must move to the left side frame, where it seneses the LEFT limit, then moves towards the right and parks at the Left Margin Position. Your problem sounds like something is interfering with the carrier movement to the LEFT limit (could be packaging). Turn the power OFF. Manually move the carrier to the RHGHT. Look inside the machine on the left side to check for foreign materials. Also check that the ribbon, correction lift-off tape, and printwheel are installed properly. GOOD LUCK!
Dec 29, 2009 | Brother EM-630 Typewriter
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
Making noise when turned on, carrier won't move
you might try unplugging machine for a couple minutes. if this doesn't work, it needs professional help
Oct 31, 2008 | Swintec 7040 Typewriter
IMB WHEELWRITER 5
Will the carrier move yo the rt. with power off ? Try a little WD40 on the silver shaft that runs thru the carrier. Look for foreign objects and debris inside the t/w.
DickyO
Aug 25, 2008 | IBM Wheelwriter 30 Typewriter
Carriage return
Try a slightly oily cloth and wipe the bar that the carrier moves on several times then with the machine turned off try to move the carrier both left and right to each end it should have some resistance but not be hanging up, you may have to do this several times. Good luck
Feb 07, 2008 | Lexmark Wheelwriter 1000 Typewriter
CARRIER WON'T RETURN BACK TO THE CENTER
make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Dec 20, 2007 | Brother GX-6750 Typewriter
Typewriter won't return carriage
try wiping the large bar that runs left to right under the carrier with a cloth wet with a light oil and then move the carrier by hand to see if it will free up. Be sure the typewriter is turned off.
Oct 01, 2007 | IBM Wheelwriter 30 Typewriter
Brother GX-6750 Typewriter Logo
203 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
