Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
How do u print confirmation from a previous fax?
I faxed a document unaware that I was out of ink. Is there a way to print a confirmation for previous faxed documents?
  • 23 Answers
All you can print out is the tranmission report. It will show the fax number the item was sent to and if it went though OK.
Posted on Apr 16, 2009
My hp 1040 fax will not print after replacing ink? yes i removed the tape
Replace right away your fax machine and your telecom line subscription! Time to switch to a cloud-based fax service: no ink, no paper, no cartridge. The internet fax service is always on, always ready - 24 hours a day, 365 days a year.
Jul 25, 2013 | HP New 1040 Inkjet Fax Machine W built in...
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Printing out a confirmation page for a document automatically
press FUNCTION, 7, 4, SET, 1, 2, SET, 2, SET, STOP...It will print everytime you fax out a document.
Oct 02, 2009 | Panasonic PanaFax UF-8000 Laser Fax
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
CANON IR2870 OFFICE COPIER, FAX CONFIRMATION REPORT QUESTION
user interface =>report settings => fax=>report on tx=>image of tx =>off
Feb 27, 2008 | Computers & Internet
Fax Error
If this is a uf8000 please follow these instructions.
fuction-7-4-start-1-2-start-2"always"-start stop.
the journal will print every time you fax out now
have a good day and good luck
Feb 15, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
331 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
