Question about B&K AVR-202
MY BASSMAN 100 MASTER VOL MODEL FROM 1972 HAS A HUM IN IT...? WHA
THIS 1972 SILVERFACE BASSMAN 100 HUMMING AMP ...WHEN YOU OPEN THE BACK THE SMALL TUBE ON FAR LEFT IS NOT BURNING BRIGHTLY LIKE THE OTHERS....IT APPEARS TO HAVE ALL THE 6L6 POWER TUBES REPLACED WITH RECENT SOVTEKS...
    Novelist:
  • 153 Answers
Well where do I begin. First, the polarity switch on the back might eliminate or reduce the hum, but by todays standards the way it functions is a deadly safety hazard (remember all the musicians that got fried in the '60's and early '70's?). That circuitry should be disabled and the unit retrofitted with a 3 prong power cord.
Next, the tube filiments are powered by AC voltage, and there is a control on the chassis for balancing it in order to reduce the hum. It could be toast or mis-adjusted. There could be a tube or other component problem causing your hum. The DC power supply could have faulty filter capacitors.
Another source of problems in these amps are the carbon resistors that introduce static noise in the audio. These should be changed to much better carbon film resistors.
If you are not comfortable working on electronic equipment with voltages in excess of 300VDC you should bring it to a pro audio repair shop.
Posted on Apr 28, 2009
  • rjivaro Apr 28, 2009
    But wait. There's more.
    First, I hope I didn't scare you. The fix for the safety issue is an easy one, but is important. The bassman amp series are wonderful classic amps and well worth the few repairs and upgrades that will make them a peak performer.
    Another issue is the sovtek tubes. The softer vacuum of soviet tubes sound great in preamps and guitar amps, but personally I have always liked the sound of the harder vacuum that american made tubes had (no longer in production). Try Groove Tubes if you want a tighter and punchier sound from the amp.http://www.groovetubes.com/
    Or maybe you will get lucky and find some old (slightly used or unused) Sylvania's.
I have a 99 blazer 4x4 it is humming in he rear end we had the rear bearings n seals changed new diff cover new fluid and it is still humming what is it??? PLEASE HELP!!!
99 Blazer driving hum,noise - Blazer Forum - Chevy Blazer Forums
blazerforum.com > ... > Steering, Suspension & Drivetrain
Dec 31, 2007 - 99 Blazer 4x4 has constant noise-humming that occurs non-stop and increases and ... Sounds like it is coming from rearend but not 100% sure. 99 LT 4x4 Rear End Whine
Nov 5, 2013
7-5/8 or 8.5" ring gear?
Jan 16, 2012
99 Jimmy 4x4 humming noise
Dec 24, 2009
More results from blazerforum.com
Sep 30, 2015 | Cars & Trucks
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Hey! I have a 1975 Silverface Super Reverb. recently, the reverb has stopped working, but I can still hear the coils vibrating if I give the amp a shake, so I'm assuming some connection is bad. If I...
The unit is screwed down. There are two screws one at each end. Look hard you will find them. Most of the time there is a small transducer (coli of wire) the small wires are usualy broke.
May 24, 2017 | Fender Hot Rod Deluxe Guitar Combo...
There is an increased humming when i turn on my amp
If most of the humming goes away when you unplug the cable from it, the amp is OK and it may be either a poor guitar cable or more likely hum pickup by the pickups on the guitar. If you move the guitar around and near the amp you likely will notice incread hum from the magnetic fields from the amp or other devices as well.
Jan 11, 2011 | Fender Super Champ XD Guitar Combo Amp
Yamaha dtxpress humming low sound in headphones and amp.
Likely a filter capacitor in power supply is failing if it has started doing this. SOMETIMES devices have a very small amount of hum normally. Also sometimes unbalanced instrument cables can pick up hum.
Feb 11, 2010 | Yamaha Music
NAD S300 Amplifer humming
You have either got a bad earth connection, or possibily there's a capacitor failed.
If you can't find a dodgy conection, I would replace the large Electrolytic Capacitors in the power section, they are used to take out 50hz hum in the mains electric, when they go you get that hum coming into your system.
Nov 15, 2009 | NAD S300 Amplifier
Humming problem
This could be a grounding problem, it might change if you plug it in elsewhere or it might be where you live.
Jan 28, 2009 | Mackie SRM-450 System
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Feedback from bass amp
first check capeciter in rectifier stage.
Oct 16, 2007 | 3Com SuperStack II advanced RPS...
246 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
