Question about SanDisk Sansa m240 MP3 Player
Formatting issue I found a solution to formatting the player. There is a patch you can download from Sandisk that will format your player for you and even give you instructions through the process. My problem is my computer recognizes another source when I plug the player into a USB port, but it doesn't find the player under My Computer. Any suggestions?
  • 626 Answers
Does the device show connected? If so check the device manager for any red or yellow errors. If there are errors, right click on the device and select un-install. Disconnect the device from the computer, wait a few seconds and reconnect. The device should re-install the drivers and device should be recognized. Best of Luck.
Posted on Sep 15, 2007
SOURCE:
Sandisk 2 gb pen drive not doing format insert usb but show u want to format and yes so not working format option so pls given me some importent tips argent
Hello friend,
You can try the following format may this can help.
Try to format the mp3 player like this method:
Go through the : Setting>Control panel>
Administrative Tools>Computer Management>Disk management>
locate you mp3 player then
Try to format fat files system.
hope this help you
Regards
uttam
Jan 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Wat type of video file type do sansa mp3 players use? i cant seem to find a file type to successfully play videos on it
The new SanDisk e260 designed to work seamlessly with a wide range of popular music formats such as MP3 and Windows Media Audio (WMA) in both unprotected and protected files (such as those WMA files purchased from music stores). It also supports the newest music subscription services found at Rhapsody to Go and others
  • Music Playback Formats: MP3, WAV, WMA
  • Photo formats: BMP, JPEG, TIFF, GIF
  • Video Formats: AVI, MPEG4, WMV, QuickTime, MPEG2, ASF
  • You can go to this website and download a free format converter.
  • http://www.formatoz.com/
  • Good Luck, I hope this helps
  • Nov 30, 2009 | SanDisk Sansa e260 MP3 Player
    Dear sir i am using sansa express 1gb .its not working at all.when i switch on the player it shows "sansa" for 2 min ,then it disappears.after that i wnt be able to open it.but my computer is dtecting when...
    There is online support for Sansa Express. When searching for Answers on the topic "express" it gives next list:
    http://kb.sandisk.com/app/answers/list/kw/express/r_id/101834
    Going to item 13 "Sansa player not recognized by the computer":
    http://kb.sandisk.com/app/answers/detail/a_id/42
    When the player is brand new, click on the link in the opened page in the page top or use next direct link:
    http://kb.sandisk.com/app/answers/detail/a_id/42#brandnew
    Else follow up the instructions as described in item 13.
    Sansa Express user guide
    If more help is needed just post a comment.
    Sep 24, 2009 | SanDisk Sansa MP3 Player
    About format
    It looks like it plays a format called MJPEG at 14 fps. The SanDisk Media Converter comes with it, and can convert most popular formats to play on the e250.
    Answer found by digging through Cnet's review.
    Aug 02, 2009 | SanDisk Sansa e200 MP3 Player
    Help!
    You may need to format, formatting should fix this problem instead of just deleting the songs.
    To format follow these simple steps below:
    First go to "My Computer" - now look for your mp3 player usually named under for example "Removable Disk F", when you've found it "Right-Click" on it then click on "Format", when format is complete try after that.
    Any further problems leave a comment on this page and i will get back to you.
    Good luck. Hope my solution was helpful.
    Nov 09, 2007 | SanDisk Sansa m240 MP3 Player
    It won't start now!
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
    Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
    Getting messgae Not enough space for MusicDB. Please free 6MB
    If it wont connect to the PC, you need to put it into recovery mode and format it with the recovery tool from SanDisk. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
    Sep 14, 2007 | SanDisk Sansa e260 MP3 Player
    Help in formatting
    try formatting using the disk management window if it still not get formatted call sandisk.
    Aug 15, 2007 | SanDisk Sansa m230 MP3 Player
    Nothing will show up ...
    first connect your player and after windows has found it open your 'my computer' folder. if you see the player listed as a drive, right click on it and then click format. You will lose all data/songs but you can always reload them later from your music library. Make sure you use FAT format if windows gives you the option. after format is complete, disconnect the player and it should reboot. After that, you may need to go to the sandisk website and upgrade the firmware. Don't try reformatting from the website. it never seems to work.
    Jul 23, 2007 | SanDisk Sansa e260 MP3 Player
    SanDisk Sansa m240 MP3 Player Logo
    37 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Joe Negus
    Joe Negus
    Ekse
     Ben
    Ben
    Level 1 Expert
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
