Question about ASUS Eee 4G Notebook
Eee PC does not turn on!!
My Eee PC does not power up when I press the On button. When I connect it to the charger to charge it, it doesn't respond at all. The orange light doesn't light up, and it doesn't charge. It's completely out of battery, so I can't use it. I don't know whether it's the charger's problem or the computer's problem. I didn't do anything to the machine, it just suddenly stopped working!! Help!
  • jordal Apr 16, 2009
    My computer just doesnot boot up. The battery is ok but the machine just stopped working.
  • eazeiler Apr 25, 2009
    when I press the power it well jest sit there and blink I have tryed everything I prest rest + took the batery out nothing will work
  • 45 Answers
There could be a variety of problems....first off try a simple power cycle..remove the battery and keep poewr adapter in...then push power button down for 1 minute...then push the power button normally and might correct problem....if not check the brick the power adapter box for lights or warmth...if not warm it could be bad power adapter....if it has warmth and lights then it could be the battery...if you have a warranty on hte computer now would be a good time to call the warranty companie...but try those steps first...they are simple troubleshooting steps...
Posted on Apr 16, 2009
  • bherman503 Apr 16, 2009
    yeah try the poewr cycle....this corrects the issue alot of the times...take battery out and keep power adapter in...then push poewr button down for 1 minute...this gets static electricity that might be causeing hte problem to get out of the computer...then power the computer up again....should come on and you can put the battery back in.
Laptop compaq will not charge will not turn on. Puting charger on it and pushing the on button i see lights once i release on button light goes out. thinking its charger or its where i plug in charger on...
Try this quick fix, if there are no issues with your charger and/or battery, this might work...
- remove battery
- make sure charger is not connected
- long press the power button for about 1 minute
- release then connect charger or power adapter, without the battery
- press power button to turn on the laptop
If this did not help, try using other power adapter.
Nov 05, 2014 | Computers & Internet
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
I have an Asus EEE PC Seashell series. It was left for a week without charging or being used. It will not power up or seem to take a charge. I've tried removing the battery for a few minutes and...
1. try to powercycle the system by pressing down the power button for 5 seconds.
2. try to take the battery out from the computer and connect the powercable from the computer directly to the outlet.
3. turn on the computer.
4.Check for any LED indicator.
5. if still nothing, possible that mobo is bad.
Hope this will help.
May 30, 2011 | Computers & Internet
Basically when i charge my laptop it wont turn on and the lights dont flash either i have tried checking the charger on another eee pc 4g laptop and worked i also tried swapping batteries but still...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
Then, un-plug the charger, an pluig-in the battery, try turn the laptop on.
Please tell us your results
Good Luck
May 15, 2011 | ASUS Eee 4G Notebook
My battery died, tryed to charge and it wouldnt thought it was the charger so bought a new one and it still wont do anything. No charge no lights no boot
pull the battery out and unplug from power, Hold the power button down for 30 seconds (really hold it down for 30 seconds :-D ). Put the battery back in and reconnect charger.
May 03, 2011 | ASUS Eee PC 1000H Laptop
My asus eee pc charger is not charging. the light om the ac adapter does not turn on. how can i fix it?
Good Day User,
1. I suggest to check your outlet if it has current. 2. If it is good, try to check your power cable connected to your charger using multi-tester. If it has voltage then your charger may has problem. 3. Consult your nearest technician.
Thank you!
Apr 17, 2011 | ASUS Eee 4G Notebook
My asus eeepc 1005HA keyboard is not working..
Try removing the battery and the charger of your laptop. After 30seconds, put it back. As soon as you press the power button keep on tapping F2. If you can still get into the BIOS. It means your keyboard is still responding. Try to restart it again, and see if you can use your keyboard.
Sep 29, 2010 | ASUS Eee PC 1000H Laptop
Moto Q Sprint Phone wont turn on
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
Feb 11, 2009 | Motorola Mobility Moto Q
Wont turn on reset button?
Sounds like damage to the USB port. Did the phone ever charge?
Look into the USB port and check for bent connectors - you may be able to straighten them. To reset - unplug AC and battery and press and hold the power button for 6 secs.
Dec 09, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
1,226 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
