Question about Garden
I have an old Huffy riding lawn mower that will not go forward. The transmission is a lever that engages the gears and the forward aprears striped. Are there any parts availble?
Yes maybe what model is your mower?
Posted on Nov 05, 2012
2 Suggested Answers
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
My 2 year old Craftsman lawn tractor will no longer go in forward or reverse. It has the hydra static gear shift. All the belts look intact. Mower blades will engage. It is a 24 horsepower. Any...
There is a lever in the rear of the rider that allows you to disengage the transmission. It is intended to make the rider easy to push around. Make sure that hasn't gotten activated. The lever is usually located just above and to the right of the hitch plate (where a trailer would attatch). Sometimes it is located under the seat near the seat hinge. Hope this helps.
Good luck.
Sep 02, 2010 | Craftsman Professional 24 hp 42" Yard...
Tractor will roll in neutral but will not drive when put in gear. Will not roll when in gear.
I had a similar issue when I first got my tractor. the problem was with the linkage in the transmission just behind the lever you engage or dis-engage to make the mower roll freely ( on mine it is on the lower right, next to the rear axel- brassish in color ) what I noticed was when I changed to position of that lever the linkage in side didnt move all the way ( kinda like how a cars door lock/latch might stick) anyhow I was able to press the linkage forward by using a long-large standard head screwdriver in side of the notch where the lever protrudes thru the transmission ...the slight click in place cured my issue hth
-p
Jun 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
May 01, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
530 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
