Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Best settings for moderate to low light viewing?
Settings for my Mitsubishi WD 62525 DLP?
  • Larry Martin May 11, 2010
    Please clarify the setting topic you need to set.
  • 64 Answers
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Posted on Aug 11, 2009
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Getting error code 12 on mitsu wd 62525 dlp tv. any help would be great.
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 part #915P026010
Part number ( #915P026010 ) you wrote is called Lamp (bulb) of Mitsubishi DLP TV.
This part is available on Parts Store approx on $200
Thank you.
Oct 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
62' DLP WD-62525
Since the set turns on and displays this message we can asume the set is working, so for the next step simply change inputs and see if something comes up, either there is nothing hooked to input 1 or the device hooked to input 1 is off or has failed
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
208 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
