Question about Electrolux Poulan Bar & Chain Oil 12 each
Material Safety Data Shet
My company uses this product but we need to have an MSDS on the bar chain oil. I tried all the possible sites and come up with "0" results.
  • hcpd2620 Apr 16, 2009
    bunnydawg
    I got the first one but it wasn't specific to the product. Thanks for your persistence -- the second one is what we needed.
    Aloha!
    Brigadier General:
  • 5,158 Answers
Does Aleve(naprosyn) or naprosyn oral contain blood thinners?
the material data safety sheet from bater chemicals
states medical conditions aggravated by exposure:- blood disorders, digestive disorders,kidney disorders, high blood pressure ,
if the following conditions are evident stomach recurring problems, gastric- ulcers, bleeding problems or taking other blood thinning or steroid ****
I would suggest that you consult with your doctor before taking the medication as it makes thin blood worse
google --msds for aleve-- for a full print out of the product
Feb 11, 2017 | Health & Beauty
C5 LDS leak fouled neighbour's driveway. Can't get the stuff off. Neighbour well racked off. Is there an 'LDS solvent ?? Robbieupnort. (C52.2Hdi173hp)
Material Data Safety Sheets are required on all chemicals liquids in the United States. One of the sections will give you recommended clean up procedures. You can search for the MSDS for your specific product here:
If this was helpful please rate yes.
MSDS Solutions Center offers 3 5 million MSDS documents available online
Nov 16, 2016 | Cars & Trucks
My husband took a double dose of zytiga my mistake; is there a concern?
Sorry, but you have posted in the wrong section. Just post another question under the health or medicine section. I hope you get a quick answer.
Sep 27, 2015 | Cars & Trucks
Looking for MSDS sheets for all purpose taping compound.
You can go to -https://www.google.com/url?
Basically joint compound consists of-
*Acrylic glue
*Crushed Gypsum
*Whiting (a form of chalk)
**Follow the link above which will lead you to a PDF and there will be info for Material-Safety-Data- Sheet -OR- MSDS
Perry Tradesman
Sep 15, 2014 | United States Gypsum Co 380501 Sheetrock...
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
Can i get instructions to download on how to change the chain on my homelite 33cc chainsaw with 14.35 chains
Got to homelite.com and input your model number.
WARNING:
When servicing, use only identical Homelite
replacement parts. Use of any other parts may
create a hazard or cause product damage.
WARNING:
Always wear safety goggles or safety glasses
with side shields during power tool operation or
when blowing dust. If operation is dusty, also
wear a dust mask.
GENERAL MAINTENANCE
Avoid using solvents when cleaning plastic parts.
Most plastics are susceptible to damage from
various types of commercial solvents and may be
damaged by their use. Use clean cloths to remove
dirt, dust, lubricant, grease, etc.
WARNING:
Do not at any time let brake fluids, gasoline,
petroleum-based products, penetrating
oils, etc., come in contact with
plastic parts. Chemicals can damage, weaken or
destroy plastic which may result in serious
personal injury.
LUBRICATION
All of the bearings in this product are lubricated with
a sufficient amount of high grade lubricant for the
life of the unit under normal operating conditions.
Therefore, no further lubrication is required.
REPLACING THE guide BAR AND
CHAIN
See Figures 34 - 43.
DANGER:
Never start the engine before installing the
guide bar, chain, clutch cover, and clutch drum.
Without all these parts in place, the clutch can
fly off or explode, exposing the user to possible
serious injury.
maintenance
Fig. 34
Fig. 35
Fig. 36
WARNING:
To avoid serious personal injury, read and
understand all the safety instructions in this
section.
n Always place the switch in the stop “ ” position
before you work on the saw.
clutch
cover
Run
Position
sprocket
Page 26 — English
cutters
bar
groove
chain drive links
Fig. 38
maintenance
chain rotation
chain drive links
Fig. 37
n Make sure the chain brake is not set by pulling
the chain brake lever/hand guard towards the
front handle to the run position.
NOTE: When replacing the guide bar and chain,
always use the specified bar and chain listed in
the Bar and Chain Combinations section later
in this manual.
n Wear gloves when handling the chain and bar.
These components are sharp and may contain
burrs.
n Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed.
n Remove the bar and chain from the mounting
surface.
n Remove the old chain from the bar.
n Lay out the new saw chain in a loop and
straighten any kinks. The cutters should face
in the direction of chain rotation. If they face
backwards, turn the loop over.
n Place the chain drive links into the bar groove
as shown.
n Position the chain so there is a loop at the back
of the bar.
n Hold the chain in position on the bar and place
the loop around the sprocket.
n Fit the bar flush against the mounting surface
so that the bar studs are in the long slot of the
bar.
n Replace the clutch cover ensuring that the
adjusting pin in the clutch cover is in the bar
chain tensioning pin hole and that both bar
studs are securely in their respective holes in
the clutch cover.
NOTE: The adjusting pin may need to be slightly
repositioned with the chain tensioning dial so
that it is aligned with the position of the bar chain
tensioning pin hole.
n Replace the clutch cover and rotate clutch
cover lock knob just enough to hold the cover
in position.
NOTE: The bar must be free to move for chain
tension adjustment.
n Lift the tip of the guide bar up to check for sag.
n Remove all slack from the chain by rotating the
chain tensioning dial clockwise until the chain
seats snugly against the bar with the drive links
in the bar groove.
n Release the tip of the guide bar and, if the chain
sags, turn the chain tensioning dial clockwise.
Repeat this process until sag does not exist.
n Hold the tip of the guide bar up and tighten the
clutch cover lock knob securely.
Jun 25, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Just tell me how to get the Material Safety Data sheet for the cannon ir 400
This link has the MSDS for the toner. I beleive it is the only MSDS available or that you would need.
http://www.canon.ca/sd_busdrivers/buzdriver.asp?lng=en&pid=84
About 3/4 the way down the page.
Nov 24, 2009 | Canon imageRUNNER 400S Copier
The printer itself won't have an MSDS report. Each of the toners and supplies come with MSDS sheets, or the address and phone #'s to obtain them from Samsung.
Jun 19, 2009 | Samsung SCX-4300 Monochrome Laser...
MSDS FOR BROTHERS TONER CARTRIDGE
Material Safety Data Sheet,
It is the form that tells you all of the components that make up a product, the chemical break down, what to do in an emergency, such as ingestion, getting in eye, etc.
Hope that helps, Mikey
Apr 04, 2008 | Office Equipment & Supplies
Electrolux Poulan Bar & Chain Oil  12 each Logo
851 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
