Question about Sony Playstation 3 (PS3) Console
HELP FOR REPAIR
I have ps3 but if i try to make switch on but same time it is going to stand by mode (if i press power switch just coming green light then coming red light and going to stand by mode no picture can you help me what can i do?
  • KODVAR Jan 08, 2008
    TOUGH LUCK TO YOU BUDDY
    V.KODIYAN, HAVE A DRINK TO SWEAT DOWN. SORRY NO WATER IN THE DESERT
    Scholar:
  • 57 Answers
Jijo This is a Motherboard or a stuffed HDD issue. You can replace the HDD without voiding the warranty and Sony will even provide the instructions whoever if its a motherboard issue you will have to send it back so....either way its an issue right now where you will have to contact Sony.
Posted on Sep 19, 2007
Red and green lights work fine, but after green off completely, help?
Generally If System Is Unused For A Certain Amount Of Time Time It Will Go Into Was Is Called Sleep Mode. Also Make Sure You Locate Your Fan And Make Sure Its Able To Pull In Air For Ventilation Which Keeps The System Cooled Down And Wont Allow System To Get Hot
Mar 17, 2012 | Sony Playstation 3 (PS3) Console
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Green light comes on but nothing on the screen
With the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this cause the PS3 to reset the display properties
Jun 13, 2009 | Sony PlayStation Portable (PSP) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
I have have a playstation 3 and when I hooked it up to my tv as I normally do there is no picture or sound. I then tried switching to my HDMI cable with the same results. Yes, I made sure I set my tv input...
Try powering on you unit press and hold the power button and the eject button for 30 sec unti the power light begins to flash thats going to reset the setting of your ps3, and if that does not work i would rec> sending it out so sony if its still under warranty or exchanging it from where u bought it.
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Ps3 power problem
all u can really do is call sony if under warranty there is nothing u can do without getting inside
Nov 18, 2007 | Sony Playstation 3 (PS3) Console
It does not turn on, remains in stand by mode.
I cannot be COMPLETELY sure of this so be careful, but doesn't the PS3's board cater for both types of power supply and therefore a step down transformer is not needed? Check the labels on it just in case, but be wary I CANNOT be certain of this...
Aug 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
172 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
