Question about Microsoft Windows XP Professional
The window can't find the hard drive
Hi I have a problem with installing a new window when I install it says, setup did not find any hard disk drives installed in your computer.
and before I have this problem I have problem with virus first it is any way to fix this problem please?
  • 745 Answers
Hi...
If your hard disk is SATA then you need to press the F6 to activate it... but you must have the diskette containing the needed drivers. But if you have a PATA hard disk then try reinserting the cable... Then try to install again.
goodluck... keep us posted for the result and problem...
happy Fixya...
Posted on Apr 16, 2009
Maxtor 32049h2 20.4 GB setup disk for windows 2000
After installing the hard drive in the computer then boot up with the Windows 2000 installation CD. Proceed with installing Windows. delete the existing partition , create a new partition, then format the hard disk in NTFS file format, follow the instruction to complete the installation.
You will also need the product installation code to complete the installation and you will need to activate the Windows license by the Internet or by phone. You will also need to install the motherboard device drivers.
Mar 14, 2013 | Maxtor DiamondMax VL 40 (32049H2) 20.4 GB...
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Jun 18, 2010 | Lenovo 3000 Y410 Notebook
Operating system not found
You can't insert a Hard drive from another PC because when it was installed on the old PC it was setup to work with the hardware for that particular computer.
You will need to reinstall a fresh copy of windows on it to make it work with the new PC it's in.Boot from CD run windows setup, format the drive then do a fresh install.
This should fix the problem, if you have any new info or need further help with any of that post back. Thank you for choosing Fixya!
May 27, 2009 | Microsoft Windows XP Professional
Xp pro set up
copy ntldr file from i386 folder and paste in C:\
steps
  1. Use the Windows Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears:
Feb 22, 2009 | Microsoft Windows 98 for PC
I reformated my hard drive and I cant load windows
1.Make sure the hard drive is installed correct and the bios found it.
2.In bios you have to put the cd/dvd as first boot and the hdd at second.
3.Load the original windows xp disk and restart saving changes in bios.
4.When prompt to pres any key do so.
5.Continue setup as new install. (if a miss one excuse as im thinking the step)
a.Enter continue
b.F8 I agree
c.d delete
d.enter sure
e.L delete
f. C create partition
g.Enter create
h.Enter Install
I.NTFS Quick Enter
Lets windows format copy some file and make a restart.
Keep windows setup all the way.
Install drivers and that it.
Let us know thanks.....Hope this help....
Sep 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
Microsoft Windows XP Professional Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
