Question about Maax Calla 6042 Bathtub - 101058-000
Hot tub jets stopped working
Hello, I changed a spa motor pump recently. It has the usual 1/12 inch input and output connections for water and a small connection on the wet-end to a tube that I assumed took air out of the pump to make the jets go. Anyway, the brass fitting to the tube was bad (rotten), so I changed that - but it leaked between the tube and fitting when I turned on the pump - BUT the jets worked. Then I drianed the tub, and slathered that tube end it with adhesive before slipping it over the fitting. When it dried, I stated it up again, and it doesn't leak, I can hear the motor running, but no jets work, and I am worried that it might somehow burn out the engine ( I couldn't feel any suction on the intake), so I turned it off again.
Do you think that I blocked the intake with the adhesive - would that cause the jets not to work, and not allow proper circulation? Suggestions?
Thank you for you time and help, Dan
  • 116 Answers
Yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
Posted on Apr 16, 2009
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Viking V300 hot tub - jets, high and low, will only run about 10 seconds, then stop, then start
This sounds to us like maybe you have an air lock in the system.
Try this:
Turn the pump on and while it is trying to operate, loosen the discharge union on the water pump until it is spraying water (do NOT unthread it very far).
Most of the time if you have an air lock this will solve the problem.
Rod
US Parts Center
Dec 06, 2013 | Home
Switching jets on trips RCD
This is usually an indicator that the high speed on your pump is bad.
Rod
US Parts Center
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
I have the ball bearings showing up in my lounger in my spa and now realize that it is probably from a spinner jet after reading several postings. I just filled the tub and put in all new chemicals. Does...
Well.. Ummm... Yes. really to be safe & responsible & to prevent any more damage. Just having it hot & using for a little bit, may be OK, but no water jets etc. No Water Pumping jets etc.
Feb 06, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Maax Calla 6042 Bathtub - 101058-000 Logo
1,392 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
