Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimmer F2020 low rpm
I have used this machine, no worries except today I started it and the trimmer head will not spin fast enough i.e rpm so slow they won't cut squat.
  • 78 Answers
SOURCE: the cable that spins the trimmer head is broken on
That cable can be purchase at any good Lawn Equipment dealer. Sometimes they have to be cut to length,so take the peices with you.
U can save a little by installing it yourself.
Posted on Oct 21, 2009
  • 29 Answers
SOURCE: strimmer starts ok but strimmer head does not spin
It sounds like the square end in the handle has rounded some and let cable slip
Posted on May 01, 2010
  • 110 Answers
SOURCE: i have a homelite f2020 series petrol trimmer i
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Posted on Jun 16, 2010
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I was given a Homelite
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
Homelite d725cd
not sure what you're trying to accomplish but the idle screw and low speed mixture screw work together. most 2 cycle trimmers idle happy at 3k rpm's... just before clutch engagement
Aug 28, 2014 | Homelite Mighty Lite Lawn Trimmer
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been...
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Apr 02, 2011 | Homelite Mighty Lite Lawn Trimmer
I have an old homelite brush king that all of a sudden won't spin the blade under a load. When there's no load it runs fine. ?? Any suggestions where to begin.
Sounds like a clutch problem. IF it is, you need to disassemble the tube shaft from the power head to get to it.Normal operation is just the opposite of what your machine is doing.
Sep 10, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Strimmer starts ok but strimmer head does not spin fast enough to cut grass
May 01, 2010 | Homelite Mighty Lite Lawn Trimmer
To remove head to refill line which way do I turn bumper knob?
As a general rule it is right hand threads on curved shaft trimmers and left hand threads on straight shaft trimmers. The major exception is on homelite manufactured units. On Homelite units the black bump knob is right hand and the red bump knob is left hand
Sep 20, 2009 | Garden
Trimmer head does not turn as fast as it should. It seems like it is slipping b/c as soon as there is any resistance (place trimmer head flat on ground) it stops. Engine sounds good. Possible connection in...
Maybe, but it sounds as though the clutch may be the problem. If you can get it to run properly except for the turning of the head, check the clutch. If it is just not running with high enough RPM's, the problem may be the engine. I would check the clutch...I may be wrong and it may be the shaft. That would be an easy fix...Lee
Aug 25, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
Jun 18, 2009 | Husqvarna 28cc Gas Line Trimmer
Loss power Trimmer HomeLite UT20002A
Check the muffler for obstructions. Remove the muffler and check the exhaust port sometimes they are near plugged. If so remove all the crud with the cylinder in up position to prevent getting carbon in cylinder. Trimm to adjust Turn both L and H set screws clockwise until they bottom the back each one out 1 and 1/4 turn. This should allow you to start the trimmer. Then rev to max rpm and adj. the H screw to max rpm. Then set the idle with the L screw with good idle without string head turning. Then when throttled it should do so without hesitation. Once this is set you may have to fine trim the H screw for max rpm again.
Mar 12, 2008 | Washing Machines
Homelite Mighty Lite Lawn Trimmer  Logo
410 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
