Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My icemake is not making ice
Ice maker not making ice
Posted on Apr 29, 2009
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    How to trouble shoot GE ice maker that is not producing ice
    Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Icemaker not making ice
    Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
    Here are some basic tips for ice maker troubleshooting2_bing.gif...
    Ice Maker Problems and Ice Maker Troubleshooting
    http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
    heatman101
    Jul 13, 2010 | Kenmore Refrigerators
    Ice cube maker not making ice
    feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
    Apr 29, 2010 | Maytag MFI2568AE Side by Side French Door...
    I've got the LFX25960ST model. The icemaker
    its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
    Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    Kenmore 53642 / 53644 Side by Side Refrigerator Logo
    361 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
