Question about E-Machines T2240 PC Desktop
Emachines WHEN I TIRN ON THE COMPUTER IT SAYSSELF CHECK YOUR AND SIGNA CABEL MONITOR IS WORKING
  • 661 Answers
This could be a fualt with either your monitor, graphics system or cable The monitor is reporting that it is turned on but not receiving a signal from the Pc it is connected to. Check that your PC is powering on (the base unit) and check that your cables are connected, and secure (at both ends if both ends undo) if the fault persists, undo the monitor cable and inspect each end for bent / broken pins. on a 15 pin monitor cable it is common for a single pin in the center of the connector to be omitted. if you find that there are bent pins in your connector it is ossible to straighten them using a small screwdriver or pliers, however be careful as these pins are not very hardy to bending and will snap off if repetedly bent. If you cannot find a fault with the cable and the PC & monitor both are powering up properly, it may be appropriate (if you have a spare or can borrow a monitor), to test on a different monitor, if the fault persists after this there is a fault with your graphics card and you will need to have your PC serviced or replace the Graphics card.
Posted on Sep 15, 2007
Where is the nearest retail store to me
Rather depends where you are!! Area 24441 could be in Coventry, Virginia or sevral other places.
May 23, 2014 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Hp 2159 monitor
CHECK ALL CABELS.TRY WITH A OTHER MONITOR IF IT WORK THE MONITOR IS BROOKEN.IF THE MONITOR DON'T WORK THE VIDEOCARD IS PROBERLY BROOKEN.
Jun 11, 2013 | Computers & Internet
Duel monitors
YOU GOT TO HAVE A VIDEOCARD WITH DUEL CONTACTS
OR A KVM CABEL POSSIBLY.
Apr 22, 2013 | eMachines E Machines Et1831-07
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
What to do when you get no signa on the monitor and the problem is not the monitor since it works on another computer
The problem is in the video graphics card or the motherboard in the computer, but that is providing that the unit powers up and everything else appears to be running, the ram memory should be subbed out one at a time because it will cause the same symptom.
Jul 08, 2012 | eMachines ET1161-05 PC Desktop
Dell xp620 is not working
No Signa where? No Wireless Signal? Or is the monitor saying No Signal?
If you are saying the Monitor says No Signal, then more than likely the Video Card in the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor does the same and displays No Signal, then your video card is bad. If the Borrowed monitor displays and works ok, then your original monitor is bad.
May 23, 2012 | Computers & Internet
E-Machines T2240 PC Desktop Logo
179 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
