Question about Epson Stylus Photo 2100 InkJet Printer
Epson 2100 printer
When switched on, the head moves to the left,stops at the end of travel and makes a grinding noise. At the same time all the red lights flash on and off.
  • fotomedia Apr 14, 2009
    All lights are flashing, and nothing is changeable !
    Can I fix this myself ?
    Epson 2100 printer
Posted on Apr 03, 2008
  • 62 Answers
Hi, it sounds like you have a print roller error. Make sure nothing is in the path of the print carriage or stuck in the printer anywhere, espically paper. You can do this by looking up inside the printer, in the papaer feeder, and in the printer cartridge install area. Also try unplugging the printer from the wall for about 5min then plugging it back in. If nothing works, you can have an epson techician repair it but it would probably cost more than buying a good used printer or a new one. I can help you find a good used printer or a new one for less if you need to go this route.
Posted on Sep 15, 2007
SOURCE:
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
Nov 16, 2009 | Epson Stylus C86 InkJet Printer
Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Oct 31, 2009 | Epson Stylus C44UX InkJet Printer
Epson r220 print head goes left and then makes a grinding sound
Your printer needs a service reset. Epson printers will only accept x number of cartridge changes / print head cleans. Basically it's telling you that the waste ink pad is saturated. It will cost about £30.00 from a local service centre
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Color 660. Not working
You could try on old Epson trick which may work and re-sync the timing system.
With the printer turned off, but still plugged into the mains, move the head unit manually back and forth three or four times. You will need to release the head stop first ... (underneath the printhead at the left side a simple lever affair - use a small flat blade screwdriver ... gently). When you've done this, and returned the printhead back to its normal starting position, moving the little stop lever in place, turn on the printer and test it out. With a bit of luck this will do the trick.
Jan 24, 2009 | Epson Stylus C86 InkJet Printer
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
Head carriage stays left and grinds
Did you check to see if the ink was low in the printer? Epson wont let you print if the ink is low, happened to me before!
Oct 22, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Problem
this happened to me and cost me £1 to get a fix from ebay. so here it is for free. The ink pad under where the printer head parks is full.Turn the printer on. Hold the stop maintenance and power buttons down for about 10 seconds. You will hear a horrible grinding noise. PULL OUT THE MAINS CABLE. Turn the printer back on and pull the mains cable out when the head moves to the left. Use kitchen roll to soak up lots of the ink. Use kitchen roll to soak up the ink about once a month. Worked for me for over a year now
STEVE
Mar 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus CX6400 not printing
The head assembly is attached to a photo sensor that tells the printer when it is at the ends of its travel.
Sounds like this mechanism is not working properly.
Check to make sure thare is no obstructions or dirt in the paths at the ends of the print head travel.
You can use an air gun to clean the printer (JUST KEEP IT AWAY FROM THE PRINTER CARTRIDGES) as the ink will FLY EVERYWHERE.....
Oct 29, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Epson Stylus Photo 2100 InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
