Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother mfc 5460 cn Paper jam problem
I recently solved the grinding sound-not initializing problem. (thanks to mixitup) but after setting back up the printer there is no grinding sound but I get this paper jam error but there is no paper in the printer.
  • 832 Answers
Thx infonet. Sorry for reading that you have another prob. Did you open the printer? In case yes, you might have disconnected the small plastic foil which leads the printhead (encoder strip). The foil is located paralell to the driving belt of the printhead. try to fix it in place again. Have a look at the foil (encoder strip): is it stained with ink? If yes you need a new encoder strip. If not you have to place the head on the leftside (where the three white disks are) You can pull the head up in that position and watch the encoder strip when pushing it back in place. Another reason could be that the head crashes somewhere on his cycling way: Open cover and press the two plastics by thumb (located on the other side of the arrow-knob facing to inside) to avoid : cover open message. Power up machine. watch the head cycling. Does it run the hole way from right to left side and back? Or does it stuck some where? Please write here where it stopps.
Posted on Sep 16, 2007
  • 62 Answers
Hi, this document should help you clear the paper jam error. http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000005674&Sympt=How+do+I+clear+the+message+Paper+Jam+from+the+display%3f+printer+jam&Model=991&ProductGroup=5&Keyword=paper%20jam Good Luck
Posted on Sep 15, 2007
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
How to remove error initial 48 in mfc j220 printer brother?
it shows that unable to print50. or remove paper jam at the back. but nothing is in..how can i resolve this problem
Oct 23, 2012 | Brother MFC-3360C All-In-One InkJet...
I have a brothers MFC 5460 CN all in one,with a paper tray jammed so it will not release.how do I get the tray to release
Hi kenttti,
I have provided link here where you can get the instruction on how you can address paper jam with your Brothers printer. It's complete with instruction and illustrations on how to release the tray as well.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother MFC-5460CN All-In-One InkJet...
My MFC-5460 is not feeding the paper. There's no jam...
Remove the paper and invert the printer and give it a healthy shake. just be careful not to drop it.
you may hear whatever is obstructing the pathway, rattling around. Use a small flash light to identify and remove it. Then shake again until all is found and removed.
... the ink jet track obstruct the paper?
Feb 02, 2010 | Brother MFC-5460CN All-In-One InkJet...
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Won't initialize
Here is Brother document on how to clear the paper jam issue:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
921 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
