Toshiba A10 - clear admin password (password forgotten)
I have a satellite A10 - toshiba. I need disable the admin password required as soon as I power on. But I dont remember such pass (I did the pass about 6 years ago). So I disassembled all note to unplug the battery. Didnt work. The pass requirements stays there. Any knows how to clear such password? Thanks in advance.
  • ERIC BAKER May 11, 2010
    Is this the bios password or the window's logon password?
Ive forgot my password for my toshiba satellite pro a10 laptop, how do i reset password? and get into it ? thanks
If you are using Windows system, you can go to safe mode to log in the default admin password to system and change your other account password. Detail from this tutorial: Toshiba laptop password reset
Sep 07, 2011 | Toshiba Computers & Internet
Tip
How to Reset Toshiba Satellite Password
"How do I reset my admin password to my <b>Toshiba Satellite laptop</b>? How to bios password reset Toshiba Satellite? I want to <b>factory reset Toshiba Satellite</b>, etc." Large amount of questions on <b><a href="http://www.windowspasswordrecovery.net/">Toshiba Satellite password reset</a></b> can be shown at anywhere. What should we do if we have to <b>reset password Toshiba Satellite</b>? Now, it is time for us to discuss such problem now!<br /><br /> 1. Is there a <b>Toshiba Satellite </b><b>recovery disks</b>?<br />If the <b>Toshiba Satellite recovery</b><b> disc</b> is created before we lost password, it will be helpful for us to solve the problem. The operation steps can be referred to <b><a href="http://windowspasswordrecovery.net/article/toshiba-password-reset.html">Toshiba Satellite password removal</a></b>.<br /><br /> 2. Are there still other accounts with administrative privileges?<br />Especially, we may always ignore the default or built-in administrator account which will save the day, such as in Toshiba Satellite XP, Vista. While, <b>Toshiba Satellite Win 7</b> has not default account password. Take Toshiba Satellite Windows 7 account with administrator rights as example: <br /> Step 1. Login Toshiba Satellite PC from the available admin account.<br /> Step 2. Start - Local Users and Groups - lusrmgr.msc (input in the Search box) - ENTER - Local Users and Groups - choose Users.<br /> Step 3. Right click the account needed to reset password, and then select Set Password.<br /> Step 4. Input and confirm the new password.<br /><br /> 3. <b>Toshiba Satellite Password Recovery</b> with free tool - Ophcrack <br />Ophcrack cracks passwords no longer than 14 characters using only alphanumeric characters. We can download its ISO image file online and then burn the file into a CD/DVD. <br /><br /> 4. DIY a <b>Toshiba Satellite </b><b>password</b><b> re</b><b>covery disk</b><br />If we are still in trouble of password cracker, we can easily get out of problem by DIY a password reset disk with professional Windows password recovery tools. There are many Windows password breakers or removals. Just take one of the most proven effective tools - Ainorsoft Windows Password Recovery as example:<br /> Step 1. Download <b><a href="http://windowspasswordrecovery.net/download.html">Windows Password Recovery</a></b> and burn .iso file to a bootable CD/DVD/USB Flash Drive via an accessible PC.<br /> Step 2. Boot the locked computer from CD/DVD/USB.<br /> Step 3. Unlock lost Toshiba Satellite password with the burned CD/DVD/USB.<br /><br /> Easy for us to break or recover forgotten Toshiba Satellite password now! The above four methods can make sure that we instantly <b>reset password Toshiba Satellite</b> laptops or notebooks for Windows 7, XP, Vista, Server 2008, 2003, etc. <br /><br /> <i>Source</i>: http://windowspasswordrecovery.net/article/toshiba-satellite-password-reset.html<br />
on May 18, 2011 | Toshiba Satellite L500 Series Notebook
I want to reset my Toshiba Satellite Pro SP-6000 BIOS Password. I have the bootable CD XPSP2 but I can ran it on the drive. so far I want to set on the CMOS setup to boot from the CD but it's show me...
BIOS passwords in modern portables require a master password to bypass/reset if the original password is lost forgotten. You will need to contact Toshiba Tech Support and if the system is not under current warranty that will probably require payment to resolve.
Jun 25, 2011 | Toshiba Satellite Pro 6000 Notebook
Toshiba satellite a215-s4697 bios password shown when i start the laptop. please guide me how to disable the password from bios. if possible expalin through circuit
Easist way to disable he password is to, restart the Pc, as it is starting up hit F8 key repetitively until you get into the boot menu. Once in the boot menu, look for Start in Safe mode, Once you start the Pc is safe mode You should get to the log on screen, It should show 1 new user, Know as Admin- The password- If there is one will be, admin or admin doesn't work try signing in with out any password.Once logged in go to your control panel and the into User Acct and disable the Password! Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Toshiba Satellite A215-S4697 Notebook PC
Have a Toshiba Satellite A10-S129 and a forgotten BIOS password. What's the best way to reset password?
Buy or make your own parallel port password removal key. eBay's the best place to buy one, and wiring diagram is free on the internet, and it's pretty easy to make one if you have a meter and a soldering iron handy. This is the ONLY way to reset the BIOS to its factory default state (and password free).
Apr 22, 2011 | Toshiba Satellite A10-S129 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          I want Drivers for satellite A10
          Go to:
          http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
          choose
          1.category
          2.Product Family and
          3.Model
          I think you might need to check the Satellite family instead of Satellite pro to find the A10
          Jan 04, 2010 | Toshiba Satellite Pro A10 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          TOSHIBA
          your motherboard's configurations is set to ask for password as soon as booting
          try using the password Toshiba ( with capital T ) or toshiba ( small t ) .. normally that's the backdoor password for Toshiba laptops .. if either don't work .. try to hold the left Shift key as soon as you boot the pc .. this also can be a solution to bypass the password.. if none is working let me know :)
          Dec 31, 2007 | Toshiba Satellite M45-S265 Notebook
          Computers & Internet Logo
          278 people viewed this question
          David Payne
          David Payne
