Question about Polaroid FLM-3734B 37 in. LCD HDTV
High pitch noise coming from the tv.
High pitch noise coming from my Polaroid 37 in when the tv in turned on. It will last about 5 minutes. I changed the power suppy but it is still a problem. Should I change the fuse as well. JK
  • 3 more comments
  • shodson58 Apr 16, 2009
    We have the same problem- over the past several weeks the noise got louder and lasted longer. This morning we tried to turn it on the blue light came on but no picture - then we couldn't turn it off so I unplugged it!!
    I could really use some help. Both my husband and I are out of work so we can not afford an $$$$ to fix.
    Thanks S
  • rdg79erac May 02, 2009
    over the last few weeks my TV has been emitting a high pitched sound that has gotten progressively worse. The TV is about 2 1/2 yrs old
  • Anonymous May 03, 2009
    high pitched sound and the picture flickers for about 5 minutes....
  • Anonymous May 05, 2009
    Same problem as explained above.
  • Anonymous May 14, 2009
    Same as read above, first loud screeching that eventually went away, now tv is locking up, cant even turn it off with power button.
  • 192 Answers
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Apr 26, 2009
I called the Polaroid company and they decided that my control panel needs to be changed and the cost is 225.00 total. They ordered the part and had it shipped here to my home and now they are suppose to send someone out to change that for me so if it works then I guess that is cheaper than having to buy a new TV.I will let you know later if it works!
We have a Polaroid TV, Model FLM3732. When we turn the TV on, there is a loud pitching noise that lasts for 3-5 minutes, and then goes off and runs normally. Is there anything we can do to trouble shoot?
The high pitch you are hearing is probably due to failing electrolytic capacitors in the power supply module. Eventually this will no longer function. A tell tale sign would be swollen caps "tops are convex" on this pc board usually 1000mf 25 v caps or simular. I would refer to competent tech for repair of module to component level.
Mar 04, 2010 | Polaroid FLM-3732 Television
Buzzing sound after only 2-1/2 years of service
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Our 37" polaroid flat screen hdtv that we plug in and when we do sometimes a screen will come up or wont come up at all. And if a screen comes up it is usually blue and then we have to change it to video 5...
see stiv0 for tips-i followed the steps and fixed my tv in less than an hour and supplies costed approx. $10.00. I used 1000uf 35v since i could not find 10v or 16v. You can find the caps at Radio Shack. Good Luck
Mar 30, 2009 | Polaroid FLM-3732 Television
Lcd tv audio
I had this problem just got it fixed it was the power supply
Mar 27, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitched noise on Polaroid HDTV
It appears like your power supply is not filtering the voltage properly and that is why you are hearing that high pitched noise. If your LCD is less then a year old, you can call Polaroid to have it repair under warranty.
If more then a year old, check the info from this link to replace the capacitors.
Let me know if you need further assistance.
Oct 07, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitched noise
The power supply is starting to fail on your LCD. The noise you hear is because the circuit is trying to provide the proper power to the rest of the circuitry and is forcing itself.
The noise does increase if you tune to an HD channel because of more demand for power for a brighter picture.
Sep 18, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
964 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
