Question about Destineer Kawasaki Quad Bikes for Nintendo Wii
Need help operating game
1. We cannot control turning the direction the bikes are going. Either we barely move the Wii remote and it turns us around, or we have to nearly shake the remote to work! 2. How do we set up two players?
If you turn with power on (pressing 1 button) then the back end will step out around the corners so blip the throttle to control it.
The other problem is lack of steering on loose surfaces,.. best bet is to get the back end to step out by applying a little back brake (A button) and then it'll start to turn.
Don't over do it though. Play about it's fun once you get the hang.
Posted on Jul 10, 2009
How do I use the red buttons on the Wii remote control and on the Wii hardware to get it to be used as #1 remote.The games I am playing require that one of the controllers need to be #1. I have been...
after you push the red buttons push the A button on the remote and that should make that remote #1 you only need to sync the remote once then you just push the A button when you turn the wii on I hope this helps if not rite back.
Feb 27, 2010 | Nintendo Wii Console
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Feb 17, 2010 | Logitech Harmony 880 LCD Remote Control
My wii remote turns off when i play a game cube game on my wii and it doesn't turn back on?
that is normal all it means is that your now using a game cube controller to operate your wii. Also, you must manually turn off your wii and reboot your wii to change games.
Jan 18, 2010 | Nintendo Wii Remote Controller
Using the Wii Wheel, uncontrollable
you might have a bad wii remote, because the wii wheel is just a case for the remote to sit in. try playing it without the wheel and see if that works. if you dont have any luck, you need a new wii remote.
Jan 13, 2010 | Nintendo Mario Kart (Wii) for Wii
My Wii remote blinks blue lights but it won't work with the Wii
you have to press A and then the remote buttons at the bottom will turn blue and make sure you have the gray thing that sits on top of ur tv is where you can directly aim the remote at and the little hands should appear.:) Hope it helps.:)
Jun 20, 2009 | Nintendo Wii Remote Controller
I bought a second wii remote it is fully charged but it flashes several blue lights then switches itself off! please help
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
Apr 23, 2009 | Nintendo Wii Remote Controller
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Wii mario kart, second wheel won't turn
I tried resyncing from the main screen, but one of the wiimotes still didn't work. I read to smack the wiimote facedown in your hand a couple of times, and that worked!!!
Apparently the motion sensor can get stuck inside, although it doesn't totally make sense, because previously when the wiimote didn't steer, it still moved on the screen to choose character, car, etc.
Dec 25, 2008 | Nintendo Mario Kart (Wii) for Wii
Wii remote
If you move your wii romote or nunchuck while it is loading, the control that was moved during the end of the load will move the character in that direction uncontrolled the whole game.
Oct 10, 2008 | Nintendo James Bond 007 in Quantum of...
Wii wheel no longer turns
If the Wii Wheel fails to operate, or operates incorrectly, check the steps below before seeking assistance.
• Make sure the Wii Remote is correctly installed in the Wii Wheel.
• Make sure the game you are playing includes Wii Wheel game play features.
• Make sure the lenses on both the Wii Remote and Wii Wheel are clean and uncontaminated with dirt or other
foreign matter.
• Make sure the batteries in the Wii Remote are not depleted.
• Make sure the Wii Remote is synchronized with the Wii console. Review the Wii Operations Manual - System Setup,
for the procedure for synchronizing your remote with the console if you need more information.
• Review the Wii Remote troubleshooting section in the Wii Operations Manual - System Setup for complete
information on troubleshooting solutions for the Wii Remote.
If your Wii Wheel still does not operate correctly after trying the troubleshooting steps, visit support.nintendo.com for
assistance and additional troubleshooting and repair options or call 1-800-255-3700.
Aug 11, 2008 | Nintendo Mario Kart (Wii) for Wii
Destineer Kawasaki Quad Bikes for Nintendo Wii Logo
83 people viewed this question
Top Destineer Video Game Consoles & Games Experts
James Wishart
Are you a Destineer Video Game Console and Game Expert? Answer questions, earn points and help others
