Question about Braun Tassimo Espresso Machine/Coffee Maker
Braun Tassimo Coffee
When brewing coffee, hot chocolate or using any other tassimo disk the unit will leak water from the base of the machine. This is not the catch cup overflowing nor not seated incorrectly.
  • 7 more comments
  • Sionnach Dec 09, 2007
    I've had exactly the same problem for a while so I decided to descale it. No use, it still leaks, every time I use it. Very annoying.
  • Laxman007 Dec 14, 2007
    Yep same problem & mine is less than 1 month old, so 'descaling' should not be the issue. The water that discharges from the bottom of the machine is warm/hot water, so I have ruled out the overflow tank as a key player in the scenario. It has to be leaking between the heating element and the output tube. Any suggestions?
    I called Tassimo & explained the same issue, they told me I need to send it back for repair (they are sending a return box) or take it back to Macys where I bought it, since it's only 28 days old, they will swap it out for a new one w/ in 30 days. So it's obviously a problem.
  • Anonymous Mar 17, 2014
    It's burning the coffee and tasting so off, it's undrinkable. Moreover, Tassimo Direct tells us that since it's out of warranty, we should throw it out. But we'd like to repair it. Who can?
  • Anonymous Mar 21, 2014
    how do I fix this
  • Anonymous Mar 24, 2014
    Water overflows when brewing coffee.
  • Anonymous Mar 27, 2014
    Water dispenser leaking
  • Anonymous Mar 29, 2014
    When i put a t disc in my tassimo, it will leak water from not only the hole its suppose to come out of, but everywhere else.
  • Anonymous Mar 30, 2014
    put disc into bosch tassimo,only filling quarter cup.
Return it, I called Tassimo & it's a problem.
Posted on Dec 14, 2007
It's most probably from the overflow which is situated behind the splashback. When the machine leaks from there it generally means that it needs to be descaled. You can use a general descaling agent powder. dissolve it into the water container filled to max, with the cleaning disc run a few cycles with 15 minute gaps between each cycle. after it should be fine.
Posted on Nov 29, 2007
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
How do you operate the Braun Tassimo Kenco coffee machine
fill tank with clean water ,turn power on , insert the T disk beverage of your choice in the disk head and close cover , the green light should be on , place appropriate cup under spout , press the button , and happy brewing ..
Jan 10, 2011 | Braun Tassimo Espresso Machine/Coffee...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Hi,when my tassimo finishes filling the cup,it
For a Braun machine, unfortunately this is quite normal as it's part of the "purge" once it has finished brewing.
The new Bosch machines do not do this and finish their cycle with a steam purge instead.
Mar 25, 2010 | Braun Tassimo Espresso Machine/Coffee...
Tassimo not fully dispensing the t-disk
I do not have experience with milk or chocolate, but for coffee and tea, at the end of a brew cycle, the green light should flip to the MANUAL light. For the next 30 seconds you have the option to press and hold the start button, to force more hot water through the pod into your cup. Give this a try to purge the pod of it's goodies!
Good luck.
Gazzer.
Dec 21, 2008 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo 3107 or 3701
Yessir, you need a t-disc to use it, because the machine reads the bar code that is imprinted on the aluminum lid of the t-disc to get instructions of how hot the water should be, and how much water should be used for the beverage you're qnting to prepare. no t-disc, no drink, no working machine. it's that simple.
Oct 23, 2008 | Braun Tassimo Espresso Machine/Coffee...
Tassimo has stopped blowing the T-Disk contents out
Internal fault, possible cause the tube that comes from the pump has perished or become separated from either pump or nozzle. If still under warranty return to tassimo. if not open unit and order replacement from spares at Tassimo.
Jim.
Mar 13, 2008 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
3,813 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
