Question about Dell Dimension 2400 PC Desktop
Dual hard drives
Can I run one hard drive with clean operating system and another with programs?
  • Tim Phipps May 10, 2009
    Thanks for the advice.
    Problem Solver:
  • 14 Answers
It is a good idea to run 2 hdds,
it is best if you put smaller one on os and bigger one on programs,
rate me,
Posted on May 08, 2009
  • 326 Answers
Yes you can.
You have many options, to do this in whatever way you wish.
Just make sure the blank drive gets formatted before trying use it.
Posted on Apr 16, 2009
What does a blinking hard drive light mean?
A blinking hard drive light indicates hard drive activity. It means that the hard drive is performing certain operations. There are many programs running in the background that need to access the hard drive to read and write data. Whenever this happens, the hard drive indicator light blinks.
Although, if it's blinking continuously and causing the system to slow down, it could also indicate that the system is low on resources such as RAM or hard disk space or it is infected with Malware. In that case, you'll need to check your system configuration. You should run a full antivirus/antispyware scan to make sure the system is clean.
GuruAid.com
May 25, 2014 | Dell Dimension Computers & Internet
System Commander 9 fails setup
Have you tried loading System Commander 9 without Linux? the reason I ask is when you run a dual operational systems there tends to be issues that come up with certain programs, there have been to many problems with this type of settup.
Apr 17, 2012 | Computers & Internet
I have a hard drive with Win 7 with programs, etc. I also have, installed, a hard drive with Win xp, No programs. I want the "Dual Boot" option on startup so that I can choose either option...
To dual boot you must partition your hard drive into two partitions and load operating systems on both partitions. I don't think you want to do this. Go to tigerdirect.com and look for a device called a TRIOS. Trios is an IDE hard drive disk selector device, which can be placed into a PC's 5.25-inch bay, that enables end users to boot easily from a choice of up to three different or same operating systems on "three separate hard drives". Simple to install, and just as easy to use
Aug 12, 2011 | Computers & Internet
I am receiving constant messages about my PC's virtual memory being low. How do I correct?
Hello.
Try freeing up some hard drive space,delete unwanted programs and files.
Go to programs,system tools and run disc clean up.after that run disc defragment.Defrag may take awhile.
This will clean up your hard drive and put it back in order.
reboot pc when done.Should get some memory back.
Jan 14, 2010 | Microsoft Windows XP Home Edition
Dual Boot
I am assuming they are both internal hard drives, If this is the case, on the back of the hard drive itself, there will be a set of pins with a little plastic connector in between two of them. This connector selects the role of the hard drive.
You want to set the Hard drive which has the operating system installed on it to MASTER and set the hard drive you want to use for extra space as SLAVE.
This tells the computer which hard drive to actualy boot from. It is not possible to run to Operating systems at the same time.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
How do I wipe my hard drive? It has been hit by a virus and most of the programs no longer work. I need to clean the hard drive and reload it. Do I need to format it first?
You can perform a clean install. When you are asked if you want to reformat , say YES. That way all will be erased, and the virus also.
Hoe it helps
Aug 29, 2009 | Computers & Internet
It possible to run 2 differant os on 2 differant hd on 1 compute
to be honest, im not sure if its possible....you can only do it using dual boot but it only uses a single hardisk with 2 separate operating system.
how to make a dual boot can be found here
supported dual boot configurations here
if you need more information, please let us know
Feb 07, 2009 | Maxtor DiamondMax® 6800 10 GB ATA-66 Hard...
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Dell Dimension 2400 PC Desktop Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
