Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan chainsaw wild thing
My chainsaw won't crank i think it need a carbuetor kit
Remove the spark plug and squirt a little bit of the fuel from the gas tank into the spark plug hole, replace the spark plug and crank it over several times.
If it runs, or tries to run... that tells you that your engine, ignition system and gasoline are good (or atleast good enough to get it started)
Next check your fuel line and the primer ball. Make sure that when you pump the primer ball that you can see it pumping fuel through the fuel lines in ONE direction only. (It's kind of hard to see, you might have to start the test with empty fuel lines).
If that fails, you need a carb kit because that's where the check valves are. (unless your primer ball is cracked, broken, or clogged)
Next check the metering diafram and needle in the carb. If the diafram is hard (not easily flexible) or if the needle valve is stuck shut the engine will not be able to get the fuel that it needs to run.
If the Needle valve is stuck, just clean it and it'll most likely be fine.
If the diaphram is hardened, you need a carb kit.
If all the above is ok and it still doesn't work... check the gasket at the base of the carb to make sure that the posative pressure pulses from the crankcase are able to make it through the little holes into the carb (that's how it pumps fuel into the carb).
That's pretty much all the easy stuff. Keep in mind that a new carb only costs about $28 at most places.
Posted on May 07, 2009
How long is the fuel line on a poulan 2375
I never really measured them as I usually install them from my bulk line packs but the fuel kit has one 25" length for the pickup line and the return kit doesn't specify length. Note the new primer bulbs uses a different size return line then the original line.
Most chainsaws lines are under 12" each.
Dec 23, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Can i get a .325 sprocked for this saw
http://www.jackssmallengines.com/sprockets_poulan.cfm
According to this list of sprockets, the Wild Thing has a 0.3937 drive shaft and they do list 0.325 sprockets with that diameter shaft, but not for the Wild Thing. Doesn't mean they won't fit but you can call them and ask if there is any other reason it won't work. May be an easy cross. Good luck!
Sep 16, 2012 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
I have a poulan wild thing and it will start just fine, but it only runs about 1 to 2 minutes and then it won't stay running. Does anybody know what it might be or what i can check. Thank you Fred
Could be the fuel pump in the carb.Should be a small rubber hose going from the carb to the crank case the simple fix would be if it is cracked.That would be a good simple start.
Oct 17, 2011 | Poulan 18" Wild Thing Chainsaw
Won't start plug is grey, and it was getting hot last time used...wild thing 18", had a torch 7 plug,2009'
A grey plug is not good, i think before you do anything else you should remove the muffler and take a look at the piston skirt through the open exhaust port, any signs of scuffing and the machine will have to come apart to assess the damage.
Aug 27, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The oil pump gear is stripped on my poulan wild thing 2375 can i get a kit for it or is there a quick fix?thanks
If the gear has gone then you will have to replace the pump, it comes as a kit part no. 530071259, this is pump complete and metal gear on the crank.
Apr 25, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
562 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
