Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Low suction to my vaccume
Suction too low for vaccume from the pump what can i do to troubleshoot
  • Anonymous May 06, 2009
    baracuda works for 1 minute and then stops, i shake the hose and it works again for 1 minute
  • 72 Answers
Backwash the pool then let it prime again and try the vacuum
Posted on Apr 16, 2009
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
When our above ground automatic pool cleaner is contected(zodiac manta) our pool pump keeps filling with water and the vaccum does not move. The hoses are fine and we have changed the diaphram just...
I think you meant that the pump keeps filling with air. You may have an air leak on the suction side of the pump. If you turn the pump off, you should not see any water leaking out of anywhere, if you see any water drip near the suction side of the pump, you should consider that an air leak and repair it.
The problem you're having seems to be an air leak. when you connect the manual vacuum or if the system is running normally, there is not nearly as much suction that is created as when the zodiac is plugged in. The air is forcefully pulled into the system when increased suction is created.
Try replacing the lid o-ring and investigate any possible places on the suction side of the pump that could be a potential leak.
Hope this helps.
Aug 01, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
The pump works well to the pool but once we hook up the vaccum it has low water pressure
THIS IS WHAT VACUUMES DO THEY RESTICT WATER FLOW, YOU NEED THE PIECE THAT ATTACHES TO THE HOSE TO REGULATE THE AMOUNT OF SUCTION. YOUR LOCAL POOL SUPPLY SHOULD HAVE IT ,, AROUND 10 BUCKS .. KOOL FIX .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL HIT THE YES BUTTON IF I WAS OF HELP THNX J
Jun 07, 2011 | Pool & Spa
WWas working just fine then hooked up vaccum and cleaned pool now the skimmer does not have any suction-- water blows out other side just fine and I have gotten all air out of lines--- any ideas
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Sep 24, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My nearly new Miele S710 vaccum cleaner just revs like mad when you switch it in but you get no suction. Could there be a drive belt between the electric motor and the vaccum pump that has come off or...
Yes this could be a case due to which there is no suction. I am posting an article which gives you a detailed description of how to open it and repair the internal parts.
http://www.sannerud.com/house/miele.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 23, 2010 | Miele Vacuums
When i put my hose in to vaccum i lose suction but with out hose it will **** your hand down the pump is workin great
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
Jun 04, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Why does my pump lose prime when I vaccum my pool?
probably have to many things open on the suction side at one time try closing bottom drain and one if the skimmers if you have more than one.
Jul 30, 2009 | A.O. Smith SQ1102 Pool Pump Motor
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
779 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
