Question about ASUS SiS Chipset CUSI-FX Motherboard
Bios Stuck my os is winxp. When i am working Continuously after 1 hour my system will stuck. also when i am going to bios within 1 minute it will stuck. why? pls
  • ameen Sep 22, 2007
    thank you
  • 661 Answers
Sounds like a thermal issue, check your coolers. remember if you are trying this after running your system for an hour, the heat sinks may be hot. be careful not to burn yourself if your CPU gets to hot your system will freeze like this, also once it gets this hot it will freeze in the bios too.
Posted on Sep 15, 2007
When i start my laptop the system doesnt boot and gets stuck after main memory check page. I need a help on this. When ever i power on system doesnt read os to laod at all and shows blank...
You will need a WinXP CD....
insert the CD and re-boot...
if boot seq is not set to boot from CD change it
restart PC...immediatly press either (F1, F2, Del) key to got to BIOS menu....
look for boot seq,
change the 1st boot dev to CD/DVd rom
save and exit BIOS menu
re-boot....
let the PC boot from CD
follow on screen inst...to reapir the OS or reinstall OS
for more info
got to my site
www.sureshayyar.110mb.com
Reg
Kris
May 08, 2011 | Fujitsu AMILO PC Laptops
When system boots an error occurs"system bios shadowed" "Mouse initialized error" just before the OS is loaded into RAM
Firstly I would enter the BIOS and set it to default. That should remove the BIOS Shadow. When you finally get it to boot, run CHKDSK/F to remove any hard disc virtual errors.
Hope that helps.
Mar 28, 2011 | Fujitsu LifeBookS6120 Notebook
I got stuck on my bios password... its not opening .. model acer aspire 4930...please tell some solution..
hi, what worked for me was to take out the battery for about 1 hour or more, that should reset the password
Mar 02, 2011 | Acer Computers & Internet
I need to install win xp on hp 540 and ineed to know if i have to configer from bios or i need win xp sata support OS?
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
Jan 08, 2011 | HP Jornada 540 Pocket PC
Where to download drivers to update the BIOS for my IBM desk-top
Ha! Old OS, old URL; possibly just an old desktop not up to the task of running WinXP.
It's a new BIOS you'd flash your system with, and probably a push between your motherboard's BIOS having an update (you'd go to the mobo's maker's site, e.g. that of ASUS, Gigabyte, Intel, etc.; read the screen-print on the board; to get the update) and telling WinXP to install anyhow using a handy force-install option.
May 02, 2010 | Computers & Internet
D520 setup locked, cannot change boot order or re-install os
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Jul 24, 2009 | Dell Latitude D510 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Can't Get To Advanced Options
XP updating to SP1 seems a little odd in february of 2008, why not SP2?
To get into your BIOS you need to hold down escape key as you turn your laptop on and keep it held down until it reports an error, then press F1 to check BIOS. You can actually alter BIOS from within the OS environment with Toshiba laptops through a utility called HWSetup and I suspect that's where your problem lies.
Make sure your audio device is enabled in BIOS and if you need to re-install HWSetup you can find it here:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=442210xml&sliceId=&dialogID=30704477&stateId=1%200%2030700832
Hope this helps,
erch.
Feb 15, 2008 | Edirol UA-4FX External Sound System
WinXP can't start.
it maybe that the bios chip is faulty or stuck in a loop as what it seems to be doing is trying to run the bios flash programme. Next time the pc boots up press F2 or Del and in the cmos settings see if the time and date is correct, if not correct it and look in all the menus for something similair to bios flash utility updates and dissable it if enabled or select off, save settings and exit for a reboot. Hopefully it will stop, that's if you can get into the bios without this programme flashing up. If you cannot stop it you will need to reset the bios and the only way may be to remove the bottom compartments of the laptop and look on the motherboard for the cmos flat round shaped battery and remove it for 10 minutes or so and then replace and try again, or only other option is to speak to sony technical as a bios problem is a serious one and cannot sometimes be resolved other than a motherboard replacement i'm afraid.
Apr 26, 2007 | Sony VAIO NV170P Notebook
ASUS SiS Chipset CUSI-FX Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
