Question about Brother DCP 115C All-In-One InkJet Printer
Dcp-150C, clean unable 46
Printer says it unable to clean 46 and I can't even shutdown printer it needs to be unplug to turn it off.
Posted on Jan 12, 2011
  • Anonymous Jan 12, 2011
Brother dcp-150c unable clean 46.how can troubleshoot this problem? plz help me. thanks
To help you troubleshoot the error 'Unable clean 46', please follow the instructions given below:
- Pull out the AC plug.
- Put back the AC plug while holding down the 'Menu' button and keep holding it (15 sec).
- Now you are entering the 'MAINTENANCE' mode and 'Error 46' pops up in the display.
- Select 8 by using the arrow buttons ,push OK and select 0 and push OK.
- 00:00 00:01 OK (the display is showing this message).
- Now push the 'MONO' button 25 times until you see PURGE: xxxxx
- Select 2, push OK, select 7,push OK,select 8,push OK, select 3,push OK.
- The purge counter indicates now: purge: 00000
- Switch OFF the printer and wait for 1 minute and Switch it ON.
- Now try to print.
If issue persists, it is recommended to contact Brother Support Center for further assistance from the link given below:
http://support.brother.com/g/b/contact.aspx?c=au&lang=en&cid=2&pcatid=4
GuruAid.com
Jun 08, 2016 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
CLEAN UNABLE 46
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Feb 25, 2011 | Brother DCP 130C All-In-One InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Clean unable 46
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
May 14, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
2,212 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
