Question about Dryers
Igniter ignites,burns about one min. then heat shuts down. dryer keeps tumbling then hear solinoids click and igniter glows then goes out then comes one then out then on again and finally gas ignites in tube.(all the while solenoids click)takes 3 hr. to dry a load. thanks; rob
  • 530 Answers
Replace those solinoids this should solve the problem
Posted on Apr 16, 2009
Dryer heats for 5 minutes then no heat, but keeps tumbling
Perhaps the flame sensor is not working. If it does not sense heat, it will shut off the gas. You might go online and search for a manual to help you troubleshoot, or go to:
http://www.repairclinic.com/
for troubleshooting help and parts. I hope this is of help to you.
Jan 16, 2014 | Dryers
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
Dryer will not heat up.Igniter is good but will not heat up. No gas smell while dryer is tumbling.problem must be elsewhere?Please help
there is two small black solinoids near the igniter., just follow the wires. they are not opening letting the gas through the safety. or the igniter is not getting hot enough to activate the solinoids. i have seen them glow but not create enough milivolts to open the solinoids
Oct 27, 2009 | Kenmore 73952 Gas Dryer
Dryer tumbles continuously but does not dry. When
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse, but in your case, i would pay close attention to the gas valve coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 03, 2009 | Kenmore Dryers
Gas dryer does not stay hot.
Hello. I can help you. Here are all of the possible problems
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Jul 04, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
