Question about Panasonic Viera TH-50PX80U Plasma TV
Comcast Remote Won't Work With Panasonic TV
I have a Panasonic Viera TH-50PX80U. I am trying to program my comcast remote to work with my television. I have tried the 2 codes that Comcast recommends, but then don't work. Do you have any idea what the code would be?
4 Suggested Answers
  • 197 Answers
SOURCE: I need the code for a comcast cable remote
go to comcast.com
Posted on Jun 07, 2009
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
gopakumarg43
  • 74831 Answers
SOURCE: need a four digit code
Hello
Four digit universal remote codes for Panasonic TV are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 27, 2011
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
How do I download a quick guide start up manual?Pan
All cable company's have a remote that can also control your TV. Flip your cable remote over and find the part number on it. On rare occasions, it might be inside the battery department instead of the back. Type that part number into your internet browser with the words guide or manual and you should find the manual u need to program your TV into your cable remote. If all else fails, call your cable provider.
Feb 16, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
Reset child lock code on Panasonic TH-50PX80U tv without remote
You can't unlock the child lock without its remote cotnrol.
Jan 16, 2013 | Panasonic Viera TH-50PX80U Plasma TV
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
The hdmi inputs all stopped working all at once. Compondent still works ( but isnt true hd).This unit is only 4 months old???
could be the switch-over from analog to digital service. contact your provider, you may need a converter box!
we just received a notice from comcast that we may need an upgrade to our system (only about 2-3 months late!!). otherwise, if your panasonic is still under warranty- contact them! they may have a fix for your problem.
gtood luck!
Oct 19, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic Viera TH-50PX80U Plasma TV Logo
294 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
