Question about Yamaha HTR-6130 Receiver
How do reset receiver back to factory setting
  • Kelvin Irons
    Kelvin Irons Apr 24, 2016
    there will be a very small hole on side back smaller than a speaker hole use tooth pick reset.
    it should cut down and restart .good luck
    Sergeant:
  • 246 Answers
Initializing PRESET
Use this feature to reset all the parameters of this unit to
the initial factory settings.
Choices: CANCEL, RESET
•Select “ANCEL”not to reset any parameters of this
unit.
•Select “ESET”to reset the parameters of this unit.
Posted on Apr 16, 2009
2 Suggested Answers
adracamas
  • 344 Answers
SOURCE: I NEED TO RESET Sony STR D365 Receiver BACK TO
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Posted on Apr 11, 2011
What are the advantages to doing a factory reset? I'am setting up tx in new place and need to start fresh. Does the tx reset?
Hello Arthur, The reset will take all of the settings back to factory default. This includes network settings and speaker settings. Thanks, FJD
Mar 27, 2016 | Onkyo TX-NR801 Receiver
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
How to reset factory settings for onkyo tx-sv303pro without the remote
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Jan 14, 2014 | Onkyo Audio Players & Recorders
AMP ERROR DISPLAY NO VOLUME
This is how to reset the receiver to factory default- not sure if it is the same reset you would do for an amp error:
Resetting the system
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the front panel STEREO/A.L.C
button, press and hold
u STANDBY/ON for about two
seconds.
The display shows RESET?.
3 Press the front panel AUTO SURR/STREAM DIRECT
button.
The display shows OK.
4 Press HOME THX to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Note that all settings will be saved, even if the
receiver is unplugged.
Unfortunately, amp errors are usually not fixable and require you to bring the receiver on for repairs or just buy a new receiver.
THANK YOU AGAIN SO MUCH! I basically got through the 1st step or so and the thing came right back on like nothing had ever happened. Although, I think what ended up working for me was actually pressing and holding the STANDBY/ON button with the AUTO SURR/STREAM DIRECT button together for a few seconds....I didn't have to reset to factory settings, nor did I have to do step 3 or 4.
Now the receiver is working just fine like nothing ever happened. All of the input AND output speaker channels all seem to be functioning normally and in peak form, and I've made sure that I have the area around the receiver well ventilated. So....thank you, again...for getting back to where I really wanted to be without having to go through the hassles of disconnecting everything and having it serviced with possible $ and time expenses.
Oct 16, 2013 | Pioneer DEH X3500UI - radio / CD / MP3...
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Reset factory settings on my devon avr 2800
From Denon support:
To reboot, turn the receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory settings.
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
Want to reset to factory settings please
While unit is on hold video6 and r/h outer source button down for 5 sec. -the display will change a message. Let go of them and the firmware will reset. Turn the main power off (pushbutton on back of the receiver) power back on...and your reset!
Aug 13, 2010 | NAD T754 Receiver
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
No sound with TV
my suggestion is to reset it to factory preset more than likely the pors that set you pu changed nothing for the origanal settings. heres how to set the reset:
1 press the masteron off on the front panelto the off position
2 press and hold the straight(effect) button then the master on off to turn on the set.
3 use the program selector to select factory presets
4 use the srtaight(effects) button to select reset then shut it off with thw master on off to lock in the setting turn it back on and you should be back to normal
Apr 06, 2008 | Yamaha RX-N600 Receiver
Yamaha HTR-6130 Receiver Logo
9,249 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
