Low psi while running continuously.
I have a Craftsman 3-gallon air compressor, model #921.153101. It is 20 months old and only used occasionally. It will only approach 30-35 psi and runs continuously.
  • 490 Answers
I am assuming this is an oil less compressor as I have never seen a crapsman compressor that is not
you need to feel around the head and see if there is air leaking anywhere usually around the tube that goes to the tank or the pressure relief valve
Posted on Apr 16, 2009
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
How many gallons/pounds of air does air compressor model # 919155612 hold
Hi sugarplum10...
Normally the tanks are regulated to about 125lbs psi
Please take time to rate me
Sep 26, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have an old craftsman impact gun model number 875-188992. what size compressor do I need for taking off lug nuts/automotive work?
The two most important specs are CFM at 90 psi (that's how fast the compressor can compress more air when the tank starts to run low) and how big the tank is. Virtually any compressor that has a top pressure rating 20 psi higher than you need for your tool (which is usually about 90 psi) and that has a tank of a couple of gallons will work. But the smaller the tank, the shorter time you can operate the tool before the compressor has to kick in. And the lower the CFM at 90, the longer you will have to wait for the tank to come up to pressure again so you can operate the tool at full pressure. If this is for occasional use and you aren't in a hurry, you don't need much of a compressor at all. If you want to operate continuously, then you should get something with a CFM at 90 psi that is higher than your tool's CFM consumption. Keep in mind that impact wrenches don't operate continuously like paint sprayers do. Good luck. Vote if you found this helpful. Al K
Jun 07, 2011 | Air Tools & Compressors
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a model 921.153101 compressor,3 gallon
the pressure regulator is at fault. It will need to be replaced
Mar 11, 2010 | Measuring Tools & Sensors
I have a Craftsman 3 gallon air compressor. When
Is your air pressure regulator set very low? Try adjusting it to a higher pressure
Mar 08, 2010 | Water Heaters
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
