SOURCE: tom tom GPS Map Updates
you go to tomtom.com and make sure you have website open before you connect your tomtom to the computer.
SOURCE: TOM TOM GPS Updates
That depends on where you got it and if the documentation for the updates was in the box.
Usually the answer is yes.
Those from Tiger Direct do.
I have used it before now with few problems.
Couple of times I have had to talk to them but they have always been good and given me a code or new code to get the updates.
SOURCE: new purchased North america map.
I am assuming that, without being a GEEK, you are sufficiently proficient with a computer. I will describe the procedure with all the necessary details. I use Windows XP and all folders I refer to are in Windows OS hierarchy. I have tried all except starting from the SD card, I happen not to have a 2GB card ready.
I suggest you read the whole post, think about its feasability from your point of view, and proceed from there. If you have any misgivings about what I say, DO NOT DO IT. I shall NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR GPS.
First of all you should install the HOME application on your computer. Then you connect your GPS to the computer. When it asks you if you want to connect to the computer tap YES, and the HOME application will launch. You may let it perform an update (if any ) of the OS (application that manages the GPS). Do not let it make any update of the OLD map. On each screen you have a CANCEL button.
Use the TomTom Home Application to backup your device. The backup will be stored on your computer, and you will be able to restore it in case of a problems.
Disconnect your GPS and insert the SD Card in slot. Then connect the GPS to the computer and let it communicate with the HOME application.
When HOME launches it will show you the internal memory of the GPS and the SD card and you are asked to select from where to run the device. Select the external SD card.
If any thing goes wrong STOP.
In the main window of the HOME application use the right arrow to go to go to Backup and restore icon. Click the icon, HOME will restore the application and the old map, all that is on the internal memory.
If that does not work, I think you should copy the content of the backup folder \My Documents\TomTom\HOME\Backup\GO\Backup01 on the SD card. and try restarting the system from the external card.
What remains to be done is to look for the new map and put at the right place in the HOME folder.
Here I will show you the directory hierarchy in WindowsXP
On my computer the map is
\My Documents\TomTom\HOME\Download\complete\map
In this directory there is folder called North_America_2GB. It contains a 1kB activation Zip archive file, a 1.5GB map zip archive, a 6kB table of contents (. toc file) and two image files.
Once the application and the map are on the external SD card you should be able to start the device from the internal memory or the SD card. When you turn it on you will probably see two icons (one of the internal mempory and the other for the SD card) . They will be flashing for a short while. You have to tap the one that you want to start with.
SOURCE: my tomtom gps display "No maps found" I already
Hi try the following advise in my previous post on how to recover missing components including missing map:
http://www.fixya.com/support/t3710244-think_deleted_actual_program_tom_tom
Hope you resolve your issue as you have several post on this issue.
Let me know how you go!
