Question about CyberPower 525SL (CPS525SL) UPS System
Unit does not back-up (stay on-line at all) when power goes out.
Everything with my Cyber Power 525SL operates normally except when the power in the house goes out. The unit just does not run at all after the power goes out. No beeps, no noises, nothing, just shuts off like there is no battery power at all inside the unit. What are possible causes? My unit is about 3 years old.
  • 39 Answers
If the battery is over 3 years old then it most likely needs to be replaced. Since it works fine except for when it is relying on power from the battery, then a new battery should make it just like new. http://www.batteryinternational.com/ups-batteries.html should have the battery you need. Hope that helps.
Posted on Jun 24, 2009
On my Cyber Power 525SL the power light goes on and off for each plug in. The power on light only stays lit for a few seconds. I didn't want to dispose of unit if there's a way to get it fixed.
The power light was going on and off. Ordered a new battery and replaced the old battery. Now a new problem started. When the unit was turned on with the new battery it would shut down immediately. Would not even cycle on and off any more. Thought it was the new battery. Tested the voltage on the new battery and it around 14 volts. I put the old battery back in and it no longer pulsed on and off any more. Further investigation it was noticed that a little white plug that plugs into the circuit board had come loose when replacing the battery. This little plug is located right by the negative terminal on the battery. It is in a very tight spot and if you push the battery into place this plug will become loose. Reseated this little plug and that solved the two problems. First replacing the defective battery and then reseating that loose plug.
Jun 20, 2011 | CyberPower 525SL (CPS525SL) UPS System
P4 PC with Antec power supply won't start when cold
I haven't heard of a sensor that keeps it from starting when too cold. Usually in electronics, if it is a cold problem, there is a cold solder joint somewhere. When you apply heat, the joint solder expands enough to make contact and once electricity is flowing, the joint stays heated due to the resistance provided by the cold joint. Since the heat is applied to the power supply, I would say that the power supply is the problem again. If the power supply is still under warranty, I would exchange it or get my money back and go with a different name brand since you've experienced power supply problems with another model.
Dec 19, 2009 | Computers & Internet
Suddenly everything lost power and the CPS1100AVR UPS unit started beeping and clicking while switching back-and-forth from 'powered' to 'battery'. Everything connected powered off, then on, then off,
Most UPS's will check the voltage of the battery periodically when the UPS is running and all is well with the AC power. If the test returns a "fail" on the voltage of the battery, many UPS's will start acting strange. It sounds like this may be the case with yours. The batteries can be changed by removing the access door on the bottom of the unit. A phillip screw holds it in. Here's a link to the battery set: http://www.batteryinternational.com/cyber-power-cps1100avr-ups-battery-ups-batteries-f1.html
May 23, 2009 | Cybernet Systems CyberPower 1100AVR...
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Oct 26, 2008 | CyberPower 525SL (CPS525SL) UPS System
JVC AV-32D305(?) turns off sound but not picture
if you know how to solder ,resolder the amplifier your tv .or check speaker
Sep 03, 2008 | JVC AV-32D305 32" TV
(Cyberpower 525SL) not working properly
There is no other known cause of the cycling on/off behavior aside from
a bad battery. IT is possible that some component of the battery relay
or inverter has failed. If this is the case it would not be repairable
outside of warranty.
Regards,
Joel Gerlach
Cyber Power Systems (USA), Inc.
877-297-6937 x7917
Jul 03, 2008 | CyberPower 525SL (CPS525SL) UPS System
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Feb 26, 2008 | Televison & Video
UPS Failure
get new fan in if its not working
Jan 27, 2008 | CyberPower 1350VA UPS w AVR & LCD...
CyberPower 525SL (CPS525SL) UPS System Logo
283 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
